This is interesting.
My comments are as such,
Why the bimini in this? If a properly tied FG is good, why do we need to double up and add more knots to something that could be more simpler? Maybe I havent understood it properly.
I use the FG in 2 different cases, maybe this will help with regards fails,
I have mono mainline with a braided leader.
I have braid with a Flouro leader.
Braided leader, the locking wraps are being cast through the guides first, tends to unravel a bit, so the slick plait is following.
Flouro leader, the slick plait is being cast through the guides first, locking wraps following. This is much better and the unravelling less.
Its not the knot unravelling really , its the tag end of the braid which unravels really, so if you can take care of that you shouldnt have a problem. Im fishing the same FG knot now the whole season on my one rod. After every few sessions, cut the frayed braid tag, add just a touch of superglue, good as new.
The FG, in simple terms, is just that, a simple leader to braid knot, when used for other stuff, its not really being used properly. The whole concept is, the tighter you pull, the tighter the braid bites into the leader, if you prevent this happening with other knots introduced, it will be all but useless.
The more fish you hook, or get stuck up on the bricks, the tighter that knot pulls, so hook more fish..it helps...!!!.....
