I went out at buffels bay on the kayak and hooked snoek on drop shot, worked well just one problem. The dropshot gets shredded instantly by the snoek's sharp teeth
Victoria Embankment, turn into yacht mole. You can fish along the pier there, and at low tide you can get onto the banks.
unfortunately you are not allowed to fish anywhere else in the bay unless off a boat.
I haven't been down for a few months, but have had some good action every now and then. Kingies prefer smaller lures, but pickhandles will smash a fairly large surface lure. They often bite me off on dropshot.
I like surface lures. small poppers for kingies (red/white with some tail flash) and bigger stickbaits (white xrap walk) for pickhandles.
rapalas work well too, but not as exiting as surface fishing. small dropshot is also effective, but pickhandles bite you off often (at lease its cheaper than pokopoko).
the gulp plastics, although more expensive, are more resilient to sharp teeth and last much longer than any of the others I have tried. I have taken many shad on the same Gulp.
the others dont usually last more than one hit never mind one being landed. try it on the snoek and see..
Hi there
Sounds like an idea !!!
But have you seen what happens when your line and lure enters a shoal of feeding snoek? They bite everything they see..... Line , knots, swivels woteva,,,, its full of teeth marks or full of holes.
I think spinners might be a bit better for this fish.
unfortunately I have not been lucky enough to find myself in such a position.
if it gets like that, spoon on wire or jighead on wire.
but since you asked about the plastics, thought id share my learnings with you. you will have the same problem no matter what you throw then.
try the gulp. you wont be sorry.
i will make sure i take pictures of this for you next time i get toothy takes.
sometimes you get unlucky, and a half minnow comes back, but they dont slice up like the others.
