Best way to join 80lb (0.8mm) leader to 25lb (0.4mm) mainline Mono to mono
Pylstert
Double the 0.4 (if you want to be fancy you can do a bimini or easier a spider hitch) and use fig 8 knots. 3 turns in the leader and 4 on the mainline. Easy the tried and tested leader knot
Spool-Song
I agree, Bimini Twist on the main line and then connect the leader to the double line of the Bimini with a triple fisherman's knot.
Spool-Song
If you want to splash out and want a slick expensive option, then you can do a Bimini twist with a cats paw onto a wind on leader in 80lb. The strength on this compared to the above, will depend on the quality of the wind on leader.
busanga
Was thinking also to make a hollow braid loop on the main .40 line and then make a wind on leader out of the 80lb with Hollow braid and join as a loop to loop wind on.
This would require two different sizes of hollow braid for the .40 and .80
There are tricks to the uni to uni..tie in fig 8 manner not uni hahaha..maintain tension on tag ends when cinching down, but dont pull them so the knot cinches down smoothly, lube the knot and line properly with spit before this, help it cinch and shape right, the fig 8's have a particular shape to them when they cinch right with the loops getting tighter/narrower towards the line/tag, like a slight pyramid/triangular shape I don't know how to describe it otherwise.. With the doubled mainline you must take care to cinch the extra line and tag down evenly with the main line, it all makes sense when you try the knot..Make sure there are no burns from slipping or pigtails on your line from cinching the knot down and do the wind the line 3 or 4 times over your hands and over your thumb and hands on knees and try break the knot with your leg strength and if you cant then a fish wont.
Once you have practiced it and are confident in it..the only reason you'd need another is when you need a smaller diameter or for some other practical reason, in terms of function, tied right this knot is perfectly functional and you don't really need another join for mono to mono..If the knot is on a light tackle setup, for bass or the likes I dont double the mainline, but the knot is weaker..If you don't cinch it down properly and it slips, it will break, the doubled line more prone to this, but I've caught many 200lb tuna and a couple 30lb plus yellowtails on the double mainline fig8 to fig8 leader, 4 turn to 3 turn...there aren't many fish in the sea that fight harder than those two so I have great trust in that knot. Was shown to me by an old timer after seeing me loose fish...He was like once you get this knot down, and the fig8 for terminal tackle and his variation on that, there aren't many other knots one needs for mono. Since that the number of knots I regularly use has gone down to less than a handful, including fg for braid etc..
You can get all fancy, but pylstert's given you the gold..and when the fancy stuff gets bust off when fishing off the rocks, or on the boat, you need to know the fig8 to fig8/ uni to uni anyway, and have it down, as you need to tie something strong quick before the bite goes off...and you arent going to be sitting there on the beach or on a rocking boat threading needles and stuff..
busanga
Thanks for the advice. i agree 100% with you guys. will practice those knots. looking on youtube but i see many ways to tie figure 8 and some ar not even real fig 8 but variations i think. iif you can point me in direction of correct way to do it would appreciate. cheers!
Pylstert
There are old South African angling books that have very good ilustrations of the fig 8 knot, its a sublte variation on the uni that just works much better with thick lines. Wind on leaders are handy when you want to use a 1.4mm leader for sharks. Not needed for other fishing.
https://www.youtube.com/watch?v=5NVybuQAaxA
Also called the centauri knot..I dont see in the tutorials or videos is one thing I left out, after making the loops and taking your tag back through them, sort of pinch or hold the loop furthest from tag, or closest to other line or hook etc, and tease out the other loops to lay along the line in the direction of the tag, to form the figure 8, then if one keeps tension on tag while pulling tight and its lubricated it will keep the right form. Some of the online videos I watched you could see the knot shape up wrong or weakly when the guys just looped and pulled tight without that step..When you try the knot it will make sense if it doesn't now..
Ja we spin on heavy rigs with 0.55-0.65 and 1.2mm leader LOL... double centauri with doubled over mainline works 100%..You going to get the 1.2mm leader cut off on the reef before that knot pops.
