Best distance reel between...
neil777
Firstly i am new to this forum and grew up fishin mostly kzn coast, and now live in the UK. i always used good old daiwa sl50sh on a 14ft blue marlin back in the day, now i am after a new reel out of the ones mentioned above. i have done loooooots of internet searches etc and i know the line capacity and drag varies between them, but all are good enough for what i am after. bassically which one has the best potential for BIG distance in your opinions
shot::S
neil777
Sorry i thoutght i put the reels! ha ha, that might help
Trini 30dc
TRini 30A
Saltist 50
Saltiga 50
Penn Fathom 30
thanks guys
Koper
Have to agree with Kopstamp here,
If you not specififly gonna target big in-eds where you need capacity, rather look at the 20 or 40 size reels for distance, smaller spool, spins easier.
neil777
Thanks, but after something bigger than a 20, I know smaller reels generally cast further, but out of the shimano 30 and daiwa 50 size which cast better, may as well add the yorium 30 to the list though, I just assumed that trinidad would throw further than toriums, there must be more pple with at least one or two of the reels I have listed who can offer there 2c !?
I dont want to start a daiwa vs shimano debate as I have reels from both, and all have there advs and disadvs, just want to know which of the ones listed would be able to chuck say 6 / 7 ounce sinker and decent bait the furtherest
kopstamp
I am not a fan of the trini 30 a
The saltiga is the one for me, but then again if your reel is setup correctly a sl50 would get very far.
Just out of interest, is your rod is matched correctly to the sinker you want to throw?
Casted a saltiga 50 on bm /6 t53 6once and head bait very far, but the setup was suited to each other,
That is your biggest area i would look to if you want to cast far. I see your rod selections should cover this, but just make sure.
THe saltiga is also the most managble to really let rip.
Def-e-nition
The Names That strike Fear into My Thumb when i lay My Grubby hands on them , in no particular order :
30 A            Probably the only Thing tiny that gives me the Creeps when i hold it ..
Fathom 30 - although- on this doohickey - we's got brakes , like a daiwa  does .  (and   like all good reels should have ...) and This puppy spins like heaven straight from de box ...........*Shiver*
As for saltiga surf - Best Little reel i have seen - build quality is completely overkill , and the Reel Should Cast The furtherest the most consistently .and for longer, too .
 I have the Saltiga , though i love to Cast  with it i don't believe it Was Ever Designed to be a distance Caster, although with it i can cast consistently , accurately , and no Drama involved . My top throw bait reel .Saltist Much the same sir .
But Them two Reels above , are in my books the ones that , with braid , can surgically remove a Thumb , and when cast Properly - willpositively haul ass in the distance department .
 Amen .
The reel will not affect the distance you cast very much......the rod will affect your distance probably far more than the reel. I throw my Torium 30 further than all my other reels including my Torque 40!
M@rius
I think I am able to add some distance by using the Trini A, but only for casting very small baits or sinkers. I find it more difficult to control with bigger baits...
M@rius
What would you guys say is the ultimate rod for casting then?
Def-e-nition
i throw my torium too - when i throw a crows nest  i remove it from the seat - and hurl it far as I can .........
:fbash
neil777
Thanx for the replays guys, I know rid plays major role but the reel will go on a century kompressor as at first and then probably a century wr300 or a ttr, all these rods have hit iver280m in the field( not by me unfortunately!) so the limiting factor to distance in this case will be the reel. I assumed the. Trinidad 30 A would get more votes as supposedly has the lightest spool, compact frame etc. I am not worried about the centrifugal brakes as I will probably fit a custom mag brake system, am happy to hear the saltiest get praise and the fathom... Torium 30 too , no salting a votes?
scorpion
Don't be in a hurry to buy a new century rod, wait till their nano carbon range is released going to take the game to a whole new level. As for the reel torium 30 or trini DC or saltiga 50. All going to do a good job.
neil777
thanks again everyone for replies, really appreciate you all taking the time.
that is a good point about the new century, i was only getting the rod middle of next year.
Really like the look of the saltiga, and sounds good on the casting front, but eeeeiiiiish she is more expensive than i first thought!
starting to think a trini 20a and a torium 30 cost the same as just the saltiga..... too many choices!
neil777
just a quick question.....again!
i looked on uk wsites and actually the saltiga is close in price to trini here!? cheapest £350, but notice its saltiga SA50, not SA50HK or HKL, so whats the difference between all these??????????
sorry for anooooother question! but this is a loooot of geld for me to shell out, want to make the most informed decision possible:fbash
Koper
I think (and this is a very big think!) the H normally refers to the profile, as in "high", so either the reel will have a low/wide profile or high/narrow profile.
That said - the large capacity reels is always a high profile, make sense to me, otherwise you end up with a 50 size daiwa thats got a 100mm spool:fbash
