benniejordaan
I finally got round to do the beaching mod on my motors.
First, pros and cons to this method.
Pro's
1. You have beaching mod only when you need it, so if you reverse hard out at sea your motors don't trim automatically.
2. There is less pressure on the oil seals and cylinder when beaching onto a steep bank at speed.
3. No serious irreversible modifications to springs
Cons
1. You must remember to release the valve before beaching.
2. Can be cumbersome when getting to it on some boats.
First thing is to find the non-return valve. and then remove it. There is a circlip in place that needs to be removed. Then use a screwdriver to remove it completely. A little oil may come out... not serious, you can top it up when you done.
Pro's
Cons
