Barbel Catfishing help
beattym25
Hi all!
I am new to this forum and to the area. I have recently arrived to South Africa around the Secunda area. I have done a lot of Catfishing where I use to live. The bait of choice was sunnie (small pan fish) or sucker heads (similar to carp). I have tried Trichardt dam with no luck. Since I am new to the Area I have been reading a lot on forums about barbel fishing around the Vaal. Is there any good spots along the river? I prefer river fishing but I will always go where ever the fish are. Also, I will have to fish from the shore. Any help would be greatly appreciated.
I have also added a picture of a musky that I caught before coming to SA. Hope you guys like it. Sorry the picture is a little blury.
Thanks to everyone and good luck!
beattym25
Thanks Kapstok! Maybe I will take a ride out there tomorrow to look at some spot. Have you had any luck using fish heads for the barbel there?
kapstok
oh yes i have, i did fantastically in villiers this year. i bettered ny PB twice and lost many that were much bigger that that. the best bait was bird and locust. once you go over the bridge turn right first street, on your right about 100 m you will see the municipal water work, turn in there and go down to the water. the spot is very good, its free of charge and its safe. there usually a old pensioner who sit there day after day. or you can continue down the street, at the bottom turn left, on right a plaas hek, open it and go inside, just make sure it closed after you enter, if the cows get out there big K@k, just be aware no trees fir shade.
good luck
beattym25
Thanks again Kapstok. I think I will head out that way next weekend. I thought I was going to have time today but it seems I ran out.
I came across this article today and I was wondering if anyone has used this setup for catfishing. Its called the Santee Cooper Rig. In the past I have fished spots with a lot of rocks and structure and I always wondered if my bait was between rocks or covered by structure preventing the fish to get to it. Has anyone used this setup? If so, have you had any luck with it? I was thinking of shrink wrapping some cork or foam around my circle hook but I didn't want it to get in the way of setting my hook.
http://www.catfishedge.com/santee-cooper-rig/
Good luck and tight lines to all!!
Stock
Welcome Beattym25.
That rig looks interesting, I'm going to give it a try.
I've used feathers from a feather duster to give bait buoyancy. I caught but may have caught anyway.
Kapstok, how far do you cast at the Villiers spot?
I went there recently but didn't catch. Was using day olds. No one was catching that day.
I got a 6.5kg barbel today at Loch Vaal.
BTW re Villiers: if you turn right just before the bridge there is a spot about 7km down that road. It's called Aquavia.
beattym25
Thanks Stock!
What type of bait did you use? I am going to try and go there this weekend and I was thinking of using fish heads. I have no clue where to get birds so I will have to stick with the heads. Hopefully I will have some luck.
Good Luck!
Stock
I use day old chicks. Some of the tackle shops and chicken farms sell them.
I'm going to Vaal River near deneysville on Friday and probably Villiers on Sunday. Send me a pm if you're going to be around on those days.
dewalds
Hi there! You can also have a look at Unicor dam. Its close to secunda and it has some good size barbel inside!
Tight lines!
beattym25
Cool guys thanks! Stock I think we are going to villiers on Saturday. I am looking into buying a bite alarm or 2. I don't want to spend a bunch of money on them. What type do you guys use? if you do
nobbles
Hi beaty,
The easiest way to relate our barbel to a guy who fished for cats in the states is the flathead catfish. Use similar techniques as you would with flatheads and you will get onto a barbel. Location of fish will be bit different but again similar to flatheads. One thing i would look for on the river is a reed bank that moves into there water, there is always a drop off from these reeds. Fish that drop off and you will start to get into some fish. Give me a message if you have any other questions.
Those rigs are whisker seeker tackle pre made snatee rig, they will deliver to SA as we speak. Im doing a tackle test on a range of their products through winter and into summer.
Stock
Kapstok- I tried your spot in Villiers on Saturday morning. Didn't get anything but nice place under the willows.
kapstok
its usually a productive spot, a pity it blanked. you mention fish during the morning, i usually have some luck at night.
beattym25
Hey guys!
Thanks for the responses. I got to Villiers around 2pm on Saturday and I tried to find the spot we were talking about. Looked like I was going to be trespassing so I decided to go to the Dam. I had no luck with the Barbel but I caught a couple carp. The Bridge that you were talking about is a one lane bridge... is that correct? I turned right and I think I saw the spot under the willows but since I haven't been there before I figured I would pass on that spot and try the dam. Has anyone fished at Grootdraai? Might try there at some point.
