Hi
The beat advice will be to go where the local boats are. I have markes but never use them.
Catching baitfish is a bit of a "hit & run" - referring if you don't have a prominent "marker" such as buoys / small beacons / pylons / wrecks /out crops / reefs blah blah.... Not sure what you are using to catch your baitfish? Do you want live baitfish or fresh bait (dead) for trolling???
What will you be using to catch the baitfish?
What I suggest, once you've cleared the surfzone, stop every 50mts or so, and cast / throw some Sabikis / little bucktails /mini spoon... that's why I call it a "hit & run" 99% you will prevail... 9 out of 10 times..."
I usually or have in the past kept those "telescopic 5' to 6' rods paired with size 4000 grinders in my boat's centre consul...
Yes, I want to catch live bait for the live well, using Sabikis![]()
LOL... then you have an answer, as I said
Hopefully the see will be normal again by that time as the water is extremely high at the moment. there is almost no beach left. I will also be there that time.
