Baitfish for barbel
DJP
Live bait is great for Cats especially if you are targeting larger fish. Anything from 15cm to 1kg can be used, but 20-30cm size is best. We in CT mainly use small carp and bluegills. Make sure the hooks you use are in correlation with your bait, don't use to big hooks on small bait or visa versa. Key is to make sure that the hook stays proud when the bait is in the water, use an elastic band to aid you with this. Remember to give the fish ample time to swallow the bait, if you worried about gut hooking use circle hooks.
On bluegills we generally use 2/0 or 3/0 and carp 4/0 or 5/0.
DJP
Skuimkop wrote:
Dis onwettig om live bait te gebruik sover ek weet maar ja 'n klein baber is dodelik om die grootes te vang.
Regtig? Sal intersant wees wat die wetgewing ivm dit is. Weet platties is onwettig in Kaap maar dis omdat die kaapse platana bedreig is.
Dink dis dalk net van toepassing op inheemse vis. Waarvan nie die karp of bluegill is nie, nie eintlik eers babers in die Wes Kaap nie.
