It's the magnetic cast control, the main spool control is on the right of the baitcaster, you use the one on the right to actually adjust according to ur lure weight.
To set it up correctly put the magnetic cast control on 1 or 2, reel the lure in so 1m of line is off the rod, then click in spool release, the lure must drop at a slowish rate, the better your son gets at casting the less brake you can use.
The magnetic spool is for once u have adjusted the lure weight, and are casting into the wind, or further than originally setup or closer etc... Its basically a FINE-TUNE adjust to the spool whereas the adjustment on the other side is the main one.
HTH
