Bait Tank
TRDwp
Hi Ouens
Don't have  much time to pump prawn and use it fresh,normally get chance to pump in the beginning of the week and when it comes to fish day its anything from 3-5 days later.Prawns are normally vrot by then or I have to freeze them which works OK but not as good a fresh live ones.Trying to find a way to keep them alive for as long as possible.So I did some research and was hoping anyone would agree it could work.
I am planning to build a bait tank for mud prawn.(can be used for bait fish too)
Setup:
1.Big container fill with seawater
2.Air pump and air stone
3.water pump
4.5L ice cream bakkies fill with sea sand at the bottom
NB*Tank will be stored in a dark cool spot in my garage!
Think it will work????
neilg
Honestly don't know.
can't think that it will work for mud prawn, but should in theory work for sand prawn(pink prawn), just wondering if they won't die of starvation ...
marine69
I think you have to worry about the following critetia TRD...
a) For them to survive in a stable environment, you would have to have about 35 - 40 cms of sand at the bottom of the tank. The more the better. Decent size flower pots might be a bit more suited to your experiment.
b) You will also need to have the correct sand as they, like bloodworm, house and feed themselves in nutrient rich sand suitable for feeding and living. You would need to get some fresh water every couple of days as well.
c) I have found that years ago i used to pump prawns the night before and keep them overnight in a bucket of water and sand, and they would generally be ok with a couple of dead ones. Then i started keeping them in a beer box full of wet newspaper and found this to work a lot better for them as they would be much firmer and more alive in the morning. My point being, prawns flats are all tidal, and i dont think that prawns are continuously submered in salt water. So you might need to work out a system where you could drain the water once or twice for a couple of hours at a time.
d) The lastly, food. Im not entirely sure what they would feed on, but im certain that they are a filter feeder of some sort sitfing sand. Now i have no idea how you are going to get around this little hurdle, but i guess that only trial and error give a few more accurate answers.
Now, i wish you all the best for your experiment and hope they do well :)
TRDwp
a)Check
b)Sand and water from Sunrise Circle should be perfect
c)remove pots from tank for coupla hours should help
d)Will have to work on that,do some more research.
Will let you guys know of the outcome.Thanx alot
NB*Push comes to shove,you can freeze prawn for a about a week in a container with the prawns just covered with seawater and freshwater mix.Pure seawater sometimes doesn't completely freeze cause of the salt.I have caught galie and dassie with old frozen prawn.
cornelius
Hi Trdkid,
Seems to me you`ll be spending your time a lot wiser by pumping prawns during the time spent on caring for those pets.
TRDwp
[color="#006600"]cornelius[/color] wrote:
Hi Trdkid,
Ya I know.The idea for the tank is just to store from pump day to fish day.
If they can sustain themselves for a week without me physically having to feed them,then it will work for me.Working shifts messes everything up,especially trying to fit a low tide into my work roster to go pump.
THE BAIT MASTER
I have a marine fish tank and the bottom is a mixture of sea sand & sea gravel and I normally feed my fish either pink or mud prawn. Well the pink prawn dont survive long but the mud prawn that do get past the fish will quickly digg a hole to hide in and they survive... I clean my tank every two weeks and then I end up with a lot of mud prawns still alive and healthy living under the sand...
Walt
Last time I bought prawns and bloodworm,couldn't fish much because of gale blowing.So took about a dozen hooks and baited them with prawns and worm and froze them in freezer.Tried them this weekend after slight defrost and seemed to work OK.But no fish around to prove if they'll bite on this "preserved" bait.Saved some money on renewing my bait though.Good idea with tank concept.Very innovative.Proof is in the pudding and it sounds like an interesting project worth trying if economically viable and components are available.And if it doesn't work you can perhaps still utilise components and tank for other fish.If it does work I'll be first customer!Had a friend that added a baby hammerhead to his tank and it ate all the other fish in a minimum amount of time.Cheers!
THE BAIT MASTER
Having a marine fish tank is a very nice hobby, but it takes up a lot off your time and about 80% of the "bait" that do manage to get past the fish do survive, they only but that dont survive is mullets & octopus...
Mullets only survive in a round tank, due to there swimming style and octopus dont easy get us to a new infiroment
miles
Hiya
Trdkid, keeping prawn for 3-4 days is quite easy. After pumping your prawns, seperate the dead ones from the living ones. Using your ice cream containers, cut the ice cream container so that its only 5cm high. Line the bottom of the ice cream container with newspaper. Put in as many prawns that will fill the bottom of the container. Should be between 30-40 prawns, depending on their size. Now wrapp the entire container in 3 sheets of newspaper. Store in the VEGTABLE rack in the 'fridge.
The prawns will last 3-4 days AT LEAST. The cold will make them go into a 'hibernating' state. When you open them to use, they should still be alive.
Your greatest enemies are air and sun. Keep them covered and out of the sun and they'll last very long.
Regards
miles
TRDwp
Bait Master:
Good,so it will work.Just to trial it now.General layout of your tank,pumps,skimmer etc etc?
Miles:
I have noticed that they go in a 'hib' state,but unfortunately my veg rack actually turned itself into a freezer rack LOL.Everything in the bottom half freezes and top half always full.Need to get the damn fridge repair man in!
