Bait scent
ajayrajh
Hi
Just watched ESA and they said Berkley baits are scented. Never knew that. Are there any other manufacturers that also do this to their baits or would one suggest buying those scent dips?
.Generaal.
They had a scent topic in the dropshot section and Van the fisherman wrote this:
"Yes, there is a garlic and nightcrawler.
They are better suited to freshwater angling but the garlic could be used in the salt as well.
The reason we use garlic, is that when a fishes skin is broken, it then emits a chemical and this chemical actually smells similar to garlic.
But, the base of the sprays are all the same, so any one of them will work."
Bigmouth
Let me rephrase,
Spike It smells stronger and lasts longer.
I am sure the other products will also work.
Johanvc
Bigmouth wrote:
Let me rephrase,
I tend to disagree. The strongest one you get is the Bang one and Ryan and MAN can confirm that lmao
HennieS
Scents in Bass fishing is used to allow the bass to hold onto the lure longer, they are not used to attract the fish. In salt water the fish is most definetly attracted by the smell most predators follow the smell to feed in the sea. Through studies in the USA they have proven that smell is one of the weakest senses of a bass and sight is the strongest, sight is reckon to be  8 times that of a human with 20/20 vision, hence the reason for line that dissapear in the water.
For the above reason I like using Spike It as it gives me oppertunity to add alternate color to my lure that can possibly cause a re-action strike. I do use Bang as well but will use bang if I miss a bite or the fish is striking short, ussually happens in spring time. Don't be scared to use scent whatever your preference it can only enhance your chances!
Herman Nel
mmmmm....ek weet darem nie ...nog nooit 'n vis gevang wat soos knoffel ruik nie,maar baie wat soos vis ruik!!!!!!!!! Die "broken skin" teorie sal bewys moet word op "mythbusters" dink ek!  LOL!
MAN
Johanvc wrote:
Bigmouth wrote:
Let me rephrase,
I agree with johan,i had to move to get rid of the smell!I'm sure bang will overpower jik easily!Does your feet still smell like bang,johan?
Bassassin
I'm with Hennie, I don't believe that bass are attracted by the scent but it causes them to hold on that little bit longer, giving me more chance to strike. I always dip my plastics in a clear scent, if the water is discoloured I might use a chartresue or red dip, but just the very tip of the tail. I don't beleive that any bass has ever smelt garlic so prefer the crawfish or gamefish scents.
I use Spike It, mainly because that's the brand that my local tackle shop sells, but I'm pretty sure that they will all work.
