Hi andriesyssel
yes you can charge the 7 A bait boats batteries with the 5A car charger
I would suggest that you invest in a Trickle charger, something like the Noco Genius G3500 3,5 AMP, I use this charger on my bait boats 7amp batteries, it is a smart charger and prolongs your batteries lifespan
Basically my bait boat makes every Friday about 6 runs off 160 - 180m in and out and it uses 1 battery that is then at 25% full.
Below something out the manual
"Amp Hour (Ah) is a rating that measures a battery’s storage capacity.
The Ah rating indicates how much amperage is available in the battery
over a twenty (20) hour period. In order to determine how many
constant Amps the battery can output for 20 hours, divide the Ah rating
by 20. For example, if you have a 100Ah battery, it can deliver 5 Amps
for 20 hours before it is fully discharged (100 / 20 = 5)."
Hoop dit help
