Backing
Sungro
Helo so I've asked about the alpha seagrand and got myself a spool of .45 and .50 I have a torium 30. Now I practised a lot and can cast 110m without any karaaineste so I want to put braid on it so that I can go and target edibles and raggies. Prob is what backing to use and how much wil I get on the reel, wil it be enough? I was thinking about bully braid or gator braid? Maybe jerry brown but I don't know where to get it. Any advice ?
Dave Batista
Hey howsit bud, go for 600m of 48lb bully braid(R500) and then fill it up with 0.5. I've got 600m of 48lb bully braid and 200m of 0.55mm on my Tor 30 with plenty space for a 1.5mm wind-on leader. Good luck.
aquadementia
backing braid needs to be as thin as possible, preferably under 0.32mm... 50lb whiplash is first choice, with 50HMP and 40lb jerry brown being very good alternatives
Sungro
Wow that's some distance you got on there dave batista. Is bully braid a good quiality braid? And does your backing need to be a bit stronger than tour topshot so when you need to lock and brake a fish of it snaps your topshot and not your backing? And is .55 for just for in-eds?
Dave Batista
I mostly slide when fishing for sharks so ja the 0.55mm is only for sharks, you could use 0.5mm but it will obviously not be as strong and not last as long if you gonna slide on it than the 0.55mm will. 0.55mm will be fine to use with 48/50lb or 22.5kg braid backing. Just make sure that when you spool the braid onto the reel you do it as tightly and evenly as you can.Good luck.
