Artlure
CarloT
Hi Ryan.
I have gathered you tha artlue pro. I'm going to my cousins farm this weekend and he has a small river with Scalys in it. We usually catch them on bread or earthworms but i'm keen to try get them on lures. What should i try? Tiny rapala's and spinners?
Ryan
I art not a pro just a humble fisherman..........
Best is small DAM in line spinners in a no 0 or no1 but only in mettalic silver  (ONLY COLOUR THAT WORKS)- you need light tackle to trow these spinners - be warned scalies will give you a hiding so buy a couple. Slow retrieve the blades must just turn.
You can also throw small cranks for them like the Salmo hornet no 2's and maybe the 4's.
I saw a 2.2kg caught last year on a DLN.....
Persevere you will come right
Hope this helps
CarloT
cool. I'll use my 6ft stilstal baslistics rod with 6lb fireline. Do I cast upstream or downstream?
BigBass
Small inline spinners and Rapalas (the small countdown). Look for moving water and eddies behind rocks ...
General rule is that fish will position themselves to face into the current to intercept food being washed down, so retrieve with the current or across the current, but experiment ...
If you retrieve against the current, make it look like your lure is "struggling" upstream and allow it to wash back downstream every now and then as if its being "overpowered" by the force of the current ... What you don't want to do, is "burn" your lure back in a fast retrieve against the current ... Although you just never know in fishing! :)
