Just a bit of advice...when I fish with braid, I tie it straight onto the lure, and fish with a slightly loose drag. Rather use your thumb on the spool to slow it down. I also dont upgrade treble hooks. It is better to loose the fish with bent open hooks than loosing the fish and the lure. If the fish does go into the reeds, first try to turn it, if all else fails rather give it line and following with your trawling motor (if you have one) You may be lucky and at least get the lure back!!. If you always try to stop it, you are going to end up with a shot drag system and you may loose more fish and lures than you actulally catch. Good luck, and report back on how the fishing went..
We had most success with bright colour lures like chartreuse....my boet with a 5.7 kg caught in 3rd lake in April this year
