kitefisher
Nepptune wrote:
Sound advice above,as for dodging the crowds,most holiday makers sleep late ,remember the sun is up on the East-coast (KZN South coast) at about 04h15-04h30,and more often than not, the wind is the most quiet it is going to be all day.
Fish any place you would dropshot, and you will be surprized to see that you dont need to cast a mile for your intended area.Use a basket if you like ,but a collapsible one gives you more mobility and movement.Hopefully the shad-season is open when you come,cos you could find plenty of those,like I said not necessarily far out.
If your'e a right-hander ,look for the bays and days that favour you,i.e the left leg of any gully to stand on when the N.Easter blows lightly,casting to the water on your r/hand-side when facing the water.If your'e not a lefty and not very adept at doing the back-cast ,then rather go holiday when the Westerly's blowing, even a mild one can drive a fly into the back of your head (floppy hats rule lol).
I personally think that drop-shotting has just about killed shore-based saltwater -flyfishing ,it is easier and also not so dependant on the wind.
p.s. I know what is recommended,and what is the best for the job,but ,many a shad has been caught on a regular 6-7 weight with floating freshwater weight forward line,(cheap to replace when you get back home and it shows signs of wear)and lastly dont underestimate the fun that you can have on wave-garrick(3-spot Pompano) right at your feet,if not even shallower,without any fancy stripping methods,just letting your fly bob around in the foam.
Enjoy.
Esatpil - Mate speak to Paul when you down on the South Coast and see what areas are working... All the KZN SC estuaries are worth a bash, but you need to put in plenty of hours... Izotcha River, Umtumvuna, Impenjati.... all will produce Rockies, Perch, Small Kingies and the odd Leerie, depending on time of year....
Also around the river mouths in the surf zones on the Snady beaches, you'll run into 3 Spot Pompano, Kingies and the likes, and gullies etc will deal up Kingies, Shad and others...
Its hard work, but rewarding.... you gotta put in alot of time and effort, but its very rewarding when it comes off...
Enjoy.
