All braid or braid and mono ?
BenBB
All,
Can you "far distance casters" give some tips here, I just bought a new Shimano EXAGE 1446, and the Saltist 50H (R2200 combo)
I also bought some 600m 0.43mm 60lb braid. I filled the whole reel, I not sure how much is on there, I would guess about 300m.
Do I keep this braid as a primary line or take some off and load with mono, say about 200m or more ?
Will I get better distance with mono or braid ?
BB
christodeb
If the reel is full i would take off some braid line, and at about 120 to 150 meters of mono, especially if you will be targeting sharks with that outfit, for eddibles braid as mainline might work, but in my oppinion i'd rather ad a topshot of mono.
Distance wise i don't think you'll get more with the braid, due to the thinkness of it.
What mono do you intend to use?
KLIPVIS
Ben that is very thick braid boet , if you can take it back and get .20 - 27mm thick max.You should be able to get at least 400m braid plus 200m mono on , maybe even load 450m braid and topshot with mono.Dont know what type of angling you do , maybe you can elaborate and then we can give advice , but for now chuck the braid.If you fish edibles it is fine to put on braid ( to save on mono in the long run ) but leave al least 200m mono on in case a few meters is lost.Always fill a reel to its maximum.The guys telling you oterwise is talking rubbish.
BenBB
Christo,
I have some 25lb about the same thickness 0.3, 0.4mm ? Can`t remember now ?
The problem I have with braid, it seems that if you don`t wind it TIGHT !!!! it seems to crow`s nest quickly !
I must say I`m not that fond of braid.
I`m a bit disapointed in the Daiwa SH50 saltist, I bought it specifically for this reason top minimize crow nests ! However I have now tightened that "little thingy miginy" on the side to MAX, and it still seems to want to RUN AWAY with the line
BB
Kathie
Welcome
I'm no expert but this is my opinion. Braid should be a smaller diameter than your mono line i.e. .26mm K/F 45LBS braid so you can maximise you reel capacity. Whiplash is thinner in diameter but very expensive. You should have loaded 600m of .26mm K/F 45 lbs and about 200m of .45mm mono line. From what I have read is that you will not have a thumb left with only using braid & no mono line loaded. Mono line can stretch & can take the impact when you strike, were as braid has no stretch & you can be towed in if you hooked into a monster. Also if you hook something big you might have to cut your braid & thats when you are going to kick yourself very hard. Braid is 6x more expensive than mono line. Rather loose mono line than your braid. For distance cast you will have to practice a lot & get your own technique. Your technique is very important & try & get your tech right before trying for distance. It took me about 6 months to get to +/-140m. Also your braid has to filled tight & evenly so you don't have any vibrations. You going to get birds nest but don't worry all will work out.
Good Luck
BenBB
Klipvis,
JIP edibles only !!! Don`t like to catch sharks, to many teeth ;)
I like to C&R (catch & release) The odd one might go home just for the effort.
It makes sense, I`ll take most off and replace it with mono, I`ll leave some 100m.
What thickess do you recomend? And what make? I used 25lb? on my previous coffee grider reel.
I`ll be trying not to do past 6 OZ weight and then some for the bait.
BB
BenBB
Kathie,
Mnnn... Already learning allot more form these few e-mail, that what the guys on ESA taught the past YEAR :cool:;)
Your advice makes sense, I will weigh the options, It seems as I would have to go and buy some new braid and mono for the job, the 65lb braid will have to be used elsewhere.
YES I`ve alway avoided PENN type reals because of the crows nets. But I`m beginning to see why, the line is NR1 and then technique. I suppose the three P`s
Practice, Practice, Practice :) are all important.
I will have to go to a dam to practice, since I`m a casual twice a year sea fisherman. I can`t waste my time practicing then.
BB
Kathie
Shot dude its a pleasure to help. Try & get an old timer to give some tips. I used to cast from my left & i was getting about 80m to 90m & every second cast a birds nest. Guys used laugh at me. Everything I did was right but my tech was way off. An experienced club angler (old timer) changed me to the right & helped me with my tech. I now get about 2 overwinds not birds nest in a session & casting at +/- 140m with a almost perfect arc. I practice every sunday at the Dam. From how I used to fish, my techs have changed a lot. You learn a lot from SEALINE.
KLIPVIS
Hi Ben for edibles you dont need to have braid unless you dont want to replace new rolls of line all the time.Problem is when using just mono you get about 450m line on a reel , so you left with 150m which gets thrown away.The idea behind braid is you only replcae 200m line everytime hence you use 1 roll of 600m , 3 times hence you save money.If you fish maybe once a year I would say forget the braid and load just the mono.There is no edibles or medium sharks which is gonna take you to the drum.( ok ok some guys will say big kingfish ) but as a rule you need not worry.If you have 350m plus of line on your reel that is fine for the time being , but if you gonna slide for big stufff your need at least 600m of line on your reel.If I was you I would put .45 mono on , the reason for the jerseys is beacuse your sinker is light and technique needs adjustment.You must reel the line on evenly and keep your finger on the line when you cast ( very slightly ) when the sinkers slows down put a little more pressure , you dont have to stop it dead.This take time buddy.
Hope this helps a little.
BenBB
All,
I followed the general idea and did the following:
I left some braid on the real, I suppose about 200m and the filled the reel with mono, KFisher 0.4 30lb. It will suffice for what I want to target.
Thanks for the advice.
Now for casting practice.
BB
1300wipass
Hi
can someone please explain the difference between Mono and braid to me and why i read it sometimes has to be used in conjunction with each other?.. sorry noob to the game here :doh
thanks gents
W
Pylstert
Hi Ben, something is wrong - the Saltist 50 should easily take 600m of 0.43mm line, if you don't like the braid stick .43mm mono on then make a knot and add another 200m, so then you just keep replacing the 200m topshot, same as you would have done for braid.
Wipass - braid line is just what it says - braided fibers and monofilament a single filament of nylon
BenBB
I think it's time you got yourself to the GP Sealine Social... check out the thread at the top of the forum... you will learn a heck of a lot from some really knowledgeable guys...
Next time you want to buy tackle, ask questions here first... otherwise it's gonna work out expensive boet!
BenBB wrote:
Christo,
BB
hey ben...first things first..do u own a saltist 50 or sl50 because there is no Daiwa SH50 saltist....
These reels are pretty fast to a learner if u dont throw with a bit off respect..further more i think a 50 size reel is a tad bit big for your rod..simple physics will tell u that a reel with a bigger spool will take a lot off energy to start spinning but also a lot off energy to stop..hence u will find your line tends to fluff up a bit..
My opinion is a 4-6ounce rod will be more suited to a saltist 40 or even a 30...i throw my saltist30 with a 5-6 ounce sinker a mile on the beach..i see u got a daiwa sl30...get learning on that reel..
Most imperative is to Get yourself to the sealine social at leeukop dam and reefman will help u out with the technique...
mag-man
[color=#006600]BenBB[/color] wrote:
Christo,
BB
BB,
Howzit Boet, have you got both the big red blocks in, also try putting a much thicker oil in the bearings. Even keep on washing the bearings out and trying a thicker oil, no need to have to tighten the spool knobs so much. hope this helps
cheers
