Air brush testers
Cam Mundy
Hi all the forums been a bit quite so I thought I'd show my first practise runs with the airbrush set I bought from Little Green Fish
Cam Mundy
its a popper and a Chisel nose shape I've been trying to perfect, the chisel nose swims really well its just getting it perfectly symmetrical that's a bit of a bugger
Cam Mundy
The netting on the inside of a pair of old board shorts I'm off to the fabric shop tomorrow to see what else might be useful
Getting them symetrical is a femal dog, anyhows you'll get to the point where a small bump will stand out like a mole heap when looking at it from say the front, and soon you'll be able to spot that tiny bump nobody else will see, just stick to it, it takes time, If you wanna grab the shortend route, get yourself one of those wooden block squares (dunno if that's what its called) but it has a solid block of wood that fits over a wooden shaft that has a nail at the end, with that you can draw the centre line even two thickness lines on the raw wood and then start sanding down till you reach these lines. after that you can sort out the tiny bumps and humps and holes.
Painting doesn't look bad at all, but i see that you're still getting used to the double action trigger system, don't worry I'm only now starting to get the hang of it, and it's been a while, Here you could close the paint screw a little more so that now matter how far back you pull the trigger it only allows a certain ammount of paint through, then all you gotta do is keep the same distance between the piece and the tip of the brush and voila, consistant thickness of paint throughout, anyhows like I said that doesn't look bad, you got the pattern to be very consistant, I'm impressed.
Cam please tell in all honesty, are you happy with the brushes?
Cam Mundy
The brush kit is superb and I couldn't be happier its top notch stuff and at a really good price.
I'm really chuffed, today was the first time I used them  and I was testing them on and  piece of white cardboard I had in the garage trying to determine what brush is best for what work. however the temptation was to great so I grabbed some of my fist plugs I turned and threaded with wire which were destined for the bin and banged these out in under half an hour.
Sitting here with a smile so broad that if i didn't have ears I would probably been mistaken for a burger::S, I know exactly what it is that you're saying, bad news is it doesn't get better, you'll be doing this most of the time, giving in to the temptation to use them on just about anything, but there's an advantage in that, soon you'll be thinking of new things to make to try them on and there goes your social life and fishing time, so perhaps not all good but at least they keep me out of trouble.....
Glad you're chuffed with them, I know I am completely and utterly happy with my set and perhaps BenReiners will be just as happy with his set by Friday (if the post-offive doesn't join in on the new Proudly South African Culture of sympathy stirkes).
Btw, are you using 2k paint? Reason for asking have you tried thinning the paint alot and then spraying it with as little as possible paint coming out the front, that way you can easily shade/fade the colours so professionaly that it will look like it was painted by a machine?  This is the difficut part, not spraying too much at a time, but rather to spray more strokes with less paint, I still struggle with that, keep on setting it to spray max paint all the time, but it's cause I can't see that well anymore... getting old I suppose.::S
PH
I've been tying to get 2K paint (Plascon?) from hardware shops.
I this obtainable from auto paint shops, maybe?
Cam Mundy
2K paint is Basically automotive paint it needs a catalyst to cure properly the catalyst also makes it cure quicker than normal paint and gives a harder finish its also easier to spray as you can use thinners to thin it down
Jake1
Nice Job CM
Im having a lot of difficulties doing the scales. Can anyone maybe tell me in detail what and how to do it. I tried the netting from onion bags but the lines are too thin and the paint also runs in behind the netting - frustrating.
Jake1
Ben REINERS
Hey Henk & CM , ek het n reply gestuur maar weet nie of die GREMLINS dit ge-jack het nie - sien nie my reply nie - M I A (Missing In Acion) ?!?
Swagman
There is a cloth that can be bought at all material shops. I forget the name but it is basically a stretchable netting. It is available in many types and net sizes, explain to the assistant. she will know what you are talking about. It is dirt cheap!
Ben REINERS
Hey Cm Mundy
I received my set from LGF - and what a whopper she is , now for me getting the last detail then off to my testing stage. Thks Henk again , gr8 stuff , did send u a PM.
  Greetings Ben
Jake1 wrote:
Nice Job CM
Jake1
That is because the paint should not run. You should be spraying a very fine mist. By the time it hits the lure it is just about dry. Rather do a few coats than trying to get it all done at once. Dilute heavily with thinners, higher pressure, little paint.
