Advice on Gear
kravkof
Hi all,
I recently went fishing with a friend and now I'm hooked.. (excuse the pun)
I know want to get some gear of my own. I quite like fishing from the shore, drop shot into the ocean. I got a bite, was quite a serious fight but then the line broke after about 40 mins. We were fishing in Central Africa - could have been a GT.
What rod/reel combo would you recommend? I was using an 8 ft Daiwa exceler and a slade 4000fd reel combo. I'd like to get a similar setup. What would be the best to get nowadays that is similar? Or what would you recommend is the best setup for casting from the beach (reeling back quickly and casting again - not sure what you call that - drop shot?)
As you can see, complete newbie. Any help would be most appreciated!
Regards
Kravkof.
Abaddon
First off ..
:welcomesea:
Now as to yr question - assume since you were using a "Grinder Outfit" you would want to stay with that.
Budget will be your first limiting factor as this aspect of the game and fishing in general, the RAND figure can get rather frightening.
Next you will have to let us know where you will be doing MOST of your fishing and what you want to target with the gear. You mentioned Central Africa, big game fish there, real tackle busters that would tax even the elite tackle! Hitting into em with el chepo setups will 9/10 times just end in disappointment.
You may well have that "hooked" sensation now and be tempted to rush out and buy all sorts of expensive gear, don't..  I am the last guy to say don't as I am a Tackle Junkie OF NOTE but let sanity prevail.
Guess one may say that is the case as you posted on this forum for advice ;)
So let us have a little more info and the boys online will certainly be doling out the advice. Some real Salty Dogs here that know those waters you were fishing extremely well and will certainly be able to point you in the right direction.
kravkof
Hi Abaddon,
Thanks for the welcome!
I'm sure this will be a pleasant community to be apart of.
Ok, since I spend a lot of time in Central and West Africa (Libreville - Gabon, Abidjan - Côte d'Ivoire, Dakar - Senegal, Lome - Togo), I think I should purchase a setup that will be suited to surf casting ( I enjoy spinning - but maybe be able to cast and leave it there and wait?) I also think the fish that around those areas are quite large so something that will handle those fish. Listening to the guys fishing here, I've heard them say that there are GT's, barracuda, queen fish etc. You never know what you're going to hook.
My budget will prob be in the R3500 range. I'm willing to pay more if it will get me a quality rig. Don't want to go cheap and regret it later.
I would also like to take my rod home and be able to catch fish in the dam on the farm. Is it possible to buy one rod for both? (Dam and Surf?)
Now the next problem is, I'm going to need a little mentoring. Is there someone that gives these kind of "lessons" for a fee? I'm a contractor but Durbs and Cape Town will be a good start.
I think that's a good start, hope you gents can part with your good advice!
Thank you.
Regards
K.
joshua02
:welcomesea:
if you want a rod for both dam and salt, you are going to have a hard time. if you get tackle for monster gts only barbel will be wroth while to target in dam.
for rods have a look at the sensation oval dc, it will be a good medium tackle set up
kravkof
Thanks joshua02!
I think for now I will leave the carp and catfish and focus on the surf spinning and casting
Abaddon
I would definitely get hold of Craig Neil aka Enigma here on the forum.
He will be able to do a purpose built rod for you in the targeting of those species you mentioned. He would also then recommend the best suited reel and terminal gear to match the rod you decide on.
The man has an EXTENSIVE WEALTH of information and I am sure he would be more than happy to get you sorted with the best outfit possible.
If you have not seen it already - here is a link  to some of the rods he has in development. These big boys certainly push the envelope when it comes to casting with a Grinder Setup.
Casting Surf Grinders
kravkof
Thanks Abaddon. I'll have a look at the link.
What do you think of this setup:
Shimano Exage 1468 with a Daiwa Saltist 50 and a 9/10' Daiwa Spinning Rod with a Daiwa Exceler 5000 Coffee Grinder?
What are good buys for those types of setups?
K.
joshua02
I had the shimano exage 1446, it was a good rod but had small eyes. if you look around you should get the rod for R600-R800.
which saltist are you looking at?
kravkof
I see there is a Saltist 50 and a 50H.. to be honest I have no clue what the difference is :doh
:imnew
kravkof
Thanks joshua02,
So do you think the gear I mentioned will be a good start into the fishing world? If not, what else would you recommend?
PeterCox
Hi there,
For a spinning set up have a look at the Berkly air and pen battle (nice combo for light tackle fishing)
If you want to enter into the 14foor HMG (big surf fishing) I would look at the assasian toray heavy, with a Trini 50 reel (would cost you a few buck but trust me when I tell you it is worth it)
Also for less money you can look at the assasin beach master range and loomis and franklin rods both are good quality. As for reels Im a shimmy fan but I have been TOLD that Dawia are as good and some believe better :)
So its all up to your budget and Target, but Enigma is your man to talk to, he can offer the best help and advise i think.
Tight lines mate
trevour
I would go for a 13ft surf rod rather than 14, you'll probably find it easier to cast and fish with, and in the 6-8 oz range, and possibly a 4 or 5 piece, the two extra tips give you some versatility. This I would pair up with a shimano Ultegra 14000(grinder,) I think it still comes with a 2nd 10000 spool, which you can put a lighter braid on, and with one of the lighter tips, giving you a 2nd totally different outfit at no extra cost. You should also be able to pick this combination up at round about your target cost.
I am no senior angling expert - rather someone who is slightly more than novice, but have used a similar outfit to what I've suggested. It's simple, easy to use, effective, and will make learning much easier than a size 50 multiplier and a 14ft rod.
FishingFever
kravkof,not to hijack your post but I am in a similar position, new to fishing and doing it off the beach or pier. The setup im considering is
1. Daiwa Windcaster
2. Kingfisher Poseidon gold class
3. 600m Braid
4. 20m Monoshock leader
5. Bionic Finger
I would to appreciate comments on this setup from the forum.
kravkof
Ok so I settled, with advice from the pro shop, on a 10' exage with a stradic 8000. Hope it will get me some decent fish!
