Advice on backing
Benbreda
Hi to all.
I need to replace the nylon on my two sea reels, saltist 50h and Torium.  I only use them for casting/fishing from the shore.  In the freshwater carp angling(with fixed spool reels) I used to put on a thicker backing folowed by my actual fishing line which was of a much thinner diameter which aided with getting casting distance and reduced drag.
Can I use a braid as my backing and then attach my high abrasion fishing line to that? or is it better to spool the reel completely with the fishing line from start to finish.  I am thinking of using 15lb(.40mm) as my mainline with a shock leader so as to maximise my casting distance.  Mainly targeting edibles.
What diameter is a good compromise between getting distance when casting but still has enough strenght to put pressure on the bigger fish?
Tks
Psy
Ben, do a search on braid backing. It has been discussed in length on the forum.
My suggestion to you, is go with a Berkley Fireline backing and bimini twist to your .40 then to your leader.
Tight lines.
Benbreda
Tks. I have a spool of 50lb fireline lying in the cupboard. I will search for the braid backing discussion on the forum.
Benbreda
I have been in Gauteng for the last couple of years so my saltwater fishing has stagnated. Going to try out the Westcoast for now, Langebaan-Dwarskersbos areas.
Possibly target Kob and White stumpnose. Not sure whether there are any bronze whalers in these stretches of water. From holday fishing up at Veldrif I know there are lots of banjo shaped sand sharks which can get up to about 8kgs but that seems to be it. I just want to be prepared for if that big one picks up the bait and heads for the backline(have enough line on the reel)
Fluffy
So mostly edibles you can just fill up with nylon....No edible is going to take 200meters of line of your reel...
200ts
Hi,  I know you after edibles but .40mm is a bit thin for a saltist50 in my opinion.  Consider going 0.45?  In my experience 0.45 is a strong line if your knots are correct. Does not break off very easily.
Joker
Hi Benbreda
Going with the slightly thicker line will give you a slight edge when the big one do take your bait.
As for using braid as backing there are two schools of thought :)
1. Braid gives you some extra line when needed. Needed when that big non-ed takes your bait. Provided its of thin dia. The 50lbs should do the trick.
2. The braid does not need to be replaced that often. All line you replace will be the topshot of your choice. Some guys use a 600m roll as much as three times to refill the topshot. So it becomes a money saver :)
rofflign
Maybe this is a dumb question but is'nt Fireline normally used as mainline (casting braid)? If so why not use it with the mono as backing.
Psy
rofflign wrote:
Spose you can use it as a top-shot.Its your call, I use it as a backing.
