advice on aevinrude 50hp cutting out when hot
ianny
hi guuys can you help me my motor cut out when hot i had the carbs coils and the cdi box checked but still does the same ^^.. what else can i check
Alien Invader
Rory wrote:
replace impellor the motor cuts for safety so you dont seize the motor
Good call Rory, we sometimes overlook the obvious!
I have had this with an old 70 Evenrude, when the coils got hot the wire apparently expanded and opened up a fault..?? Once cooled down it would fire up again... Had it rewired and all sorted....
NB! When cold all the resistance and continuity was exactly the same as the other motor...
The rewinders have an oven they put the coils in to test under load and heat, this is how they picked up the problem on mine.
ianny
thanks guys i think Alien is on the right track because i ran the motor with muffs and when hot did the same cut out.
