Advice needed from all the wind knot specalists
Mazeppa Bay
A friend of mine purchased a Penn Battle 4000 and balanced it out with a Loomis & Franklin 9' spinning rod. The rod and reel combination in my opinion, absolutely compliments each other, untill... the dreaded wind knotts hit him.
When we spooled the 20 pound Suffix braid on the reel we did so very tightly. (Take that equation out.)  We did spool it like you would with a normal multiplyer with the spool running and not held to the side (fixed) if you know what i mean.
He has tried his Daiwa Excellor reel on the same rod and cannot get any wind knots, no matter how hard he tries. The opposite happens when he replaces the reels.
I thought it could be the first 2 eyes being a bit small but these eyes on the rod are the same size as the Daiwa Excellors. The spool appears to be flared so it can't be that.
Is there anyone out there that is a guru at this and maybe can part some advice. I have checked his action and it appears to be fine. I have asked him to allow for as much lag in his cast but this does not help.
The last resort for him is to enlarge the eyes without checking out all advice. So please if there is any constructive advice please help with some good tips.
Would a thinner braid be better or maybe a suffix fuse that is thicker with that coating on it. Look forward to hearing your advices.
Mazeppa Bay
He has his spool 3/4 full from all the knots and braid he has lost. Somone said to me he needs to take off the braid and re-spool it. Not sure if this would help, as braid has not really got that much memory if at all.
FLUKE
The other option is to top up with some 8 or 10 Lb Fireline. It's expensive but it really is better.
I still used to get wind knots with a full spool even with the Fireline.
Wind knots are the very reason I fish 90% with multiplier reels.
