You can't attach an image, but you can insert one if you have it stored somewhere else on the Internet (like PhotoBucket or Picasa web albums). I use Picasa, although it's not as convenient to get the link to the actual pic.
Once you have the link to the image, you can insert it either by using the "Insert Image" button at the top of the message or by manually using the IMG tags. Replace the round brackets with square brackets and insert your link:
(IMG)YourLink(/IMG)
Notice that there is no "
Attached Image (viewed xx times)" message with this image, and I can still continue to type below the image. You can also add multiple images to posts and PMs in this way, but you have to upload it to some other site first.
