A weekly "pull test" or two
riekert
The value of a weekly "pull test" or two:
I have gotten into the habit of doing a "pull test" on my spinning setup at least once or twice a week, depending on how many spinning sessions I do that week.
What I do is to tighten the drag on my spinning reel to the setting that I use when casting. It is tight enough so that the spool does not slip during casting of 2 oz spoons and plugs, and also not when I make the initial hookup with a fish. If it is a good fish the drag setting will allow the fish to pull me flat and allow it to take at least a bit of line until I can respond by losing the drag a bit more for the ensuing fight. On my Stradic 5000 reel with carbontex drag washers this is about 3.5 anti-clockwise rotations of the drag knob from the fully tightened position. Once set I don't fiddle with the drag during a spinning session, unless I am lucky enough to hook into a good fish! That has been quite a while ago now...I always loosen my drag after a spinning session though.
With the drag set at this "tight" position and the reel rigged onto my spinning rod with 3.5 m braid leader, 1 - 1.5 m fluorocarbon leader and Swannel kwik clip at the front end I then attach a spoon rigged with hook and attach it to a heavy metal drain cover at home. The next step is to start walking briskly away from the drain cover so that the pressure causes braid to peel of the reel.
In this way the integrity of my fluorocarbon leader to braid leader FG knot and braid leader to casting braid FG knot, as well as the first few meters of casting braid below the braid leader, gets a proper test. If all holds during the test it gives me great confidence that nothing will fail if I would hook into a really good fish during my next spinning session.
More importantly the pull test also gives me information about the smoothness of my drag. Not long ago my drag was still perfect when I did the pull test. But two sessions later (not getting any bites), when I did the next pull test, the drag was horribly sticky. Imagine hooking into a big fish only to discover this nasty problem then! So I promptly took the drag washer stack apart, rinsed the carbontex washers in benzene and re-greased them with Kingfisher drag washer grease. Put the lot back together again and retook the pull test. Drag smooth again as a babies bottom!
I find the weekly "pull test" hugely valuable as part of my preparation for spinning sessions.
PatrickH
Good point. Somehow in the excitement of preparing for the next day we lose sight of testing our connections.
You may have helped saving many guys from losing the fish of a lifetime.((goodp_
