A lure type for life
If you could only fish with one type of lure for the rest of your life, which would it be?
  • Soft plastic
    Votes: 0 0.0%
  • Bucktail leadhead
    Votes: 0 0.0%
  • Spoon
    Votes: 0 0.0%
  • Slider
    Votes: 0 0.0%
  • Surface walker
    Votes: 0 0.0%
  • Chisel nose popper
    Votes: 0 0.0%
  • Chug popper
    Votes: 0 0.0%
  • Lipped diving lure
    Votes: 0 0.0%
  • Total voters
    0
Nepptune
Angleo - The bucktail requires no additonal weighting as its weighted already, like a jighead you use for fishing soft plastics on...If you have a look at the pic of the bucktails, you'll see they have weighted heads... also come in a variety of shapes which all effect the action...
Most folks always try fish the lightest weight possible for the conditions... the action is just better... but that being said, there is no point using a 1/8 Ounce Bucktail when you are fishing in 30 metres of water with a roaring 3 knot current... you'll never reach bottom....
Similarly you don't wanna be throwing a 3 oz Bucktail when you fishing a quiet backwater estuary thats 1 metre deep....
Also wind conditons will also determine your weight, along with the set up.... if you are casting into the wind, fishing a light set up, with a very light bucktail, you will battle, and the wind will actually prevent you from reaching your target distance, as well as staying in proper contact with your lure.... I feel that it is essential to stay in touch with the lire at all times, as you very often will get hit on the drop...
In rougher surf conditons, I will also fish a slightly heavier leadhead to get the Bucktail down below the wash and into the target zone without it getting washed all over the place...
Hope that helps.
G
Guest
Guest
hello folks
I agree that a bucktail is by far the most versatile but my favourite is a home-made chisel nosed popper. There is no more exciting way to fish especially when a hole appears behind your plug. Have a 9 kg leerie hit you so close to your yak that you get wet from the splash and you are hooked for life. Would love to be able to target GT from a yak but not much chance of that in my area. Guess that a leerie is the next best. This would be first choice in the way that  iwould like to catch the whatever fish.
Anton
Dingleberry
Gotta drag yer yak through to Moz sometime. Plan Feb - March. PM me and I'll give you details of places where you'll have GT's climbing onto yer yak to get hold of that thing!:)
angelo
Hope that helps.
Hi  Neptune
i  May  sound a bit  Dof,but Do  you  use  this  bucktail on  dropshot  only????????
:imnew
Marshie
Angelo, to answer your question... yes.  99.9% of the time I fish it with just the bucktail.  On occasion you can add a curly tail grub or paddle tail to make the lure "push" more water.  This method is particularily effective on ambush predators in low light conditions.
Nepptune
Angleo - To add to Marshie's comments, I fish Bucktail leadheads on everything from my lightest outfit, up to 9 ft casting rods and everything in between.... depends on the conditions and the target species.... I wouldn't fish a 1/8 once bucktail on my 8'3" Carpenter with a Stella 20000, I'd more likely be throwing much heavier ones in the 3 to 8 ounce range.....or whatever the situation, and tackle demands...
Hammertime
Now we talking fishton. Add a big Yamashita plain white (not pearl) squid behing a big williamson bird and we done!
If I could, I'd marry an xrap!
Hammertime
If I could only take two lures anywhere in the world with me, these would be them.
Both rigged with 150lb fluero leaders.
If it came down to only 1. The redhead X-rap. Because to quote the Highlander " there can be only one"
Fishton
@ Hammertime - I am going to copy your top rig if you don't mind. JFIS, what speed do you pull your 30' X Raps at?
Hammertime
Fishton, copy away. Nothing secret on that rig, pretty much standard out there.
I pull the raps at 5.5 to 5.8 knots. I have had strikes when dropping to 4.5 and only longfin on the higher speeds of 6.2 knots.
dugongboy
[color=#006600][/color]wrote:
Soft plastics are costly bru, and most often one bite = one soft plastic @ almost R10 a shot!
This cost me R7.13 and I dident even get the shad, I went through a packet in about 5 mins. and only got 1 shad out -  the bucktail did a lot better but after about 10 shad and 8 catfaces I had to go buck hunting !!  hehheh !!!
G
Guest
Guest
Hello Tony
I can only speak for the chisel nosed plugs. I make them myself out of a hard plastic similar to teflon called polliprop(forgive spelling). I generally use two colours, white or green. Once you have the material you take it to someone who can cut into strips. I have certain width and thickness that I like. You then cut the length plug you want, drill a smaller hole one end(nose) and a larger hole the other that must meet the smaller hole. You then shape your plug by using some sort of grinder. I use stainless steel wire in the middle of the plug. Diameter varies as to plug size. Push the wire through the plug and then bend a loop at each end. The trick is to make sure that enough of both loops goes back into the holes you have drilled. Put a swivel onto the front loop. Melt lead and pour it into the back hole until plug is full of lead. Add split ring and treble to rear loop and you are done.
Good thing with this is  that you can really experiment with plug size, amount of lead ie weight etc. You will generally find that one or two plugs from a batch are just right as they skip effortlessly while others tend to dig a little. Fish the ones that work the best.
Good luck
Anton
Revo
Dugongboy. There are only two things that can happen when you're fishing soft plastics and the Shad are around. Firstly, they will munch them to pieces, and like you have discovered, it's a costly excercise, and secondly, there are very few soft plastic brands that fish can digest, so it's really not good for them. In fact most soft plastics will swell up to 4 times their size in a fish's stomach. If you're targeting other species and the Shad rock up, change to hard lures like spoons, plugs etc.
There is one lure that I have found to outfish anything else when it comes to light tackle artificial lures and that's the Yozuri Mag Minnow in green mackrel. Kingies go beserk for that lure. They have razor shark hooks, but they are a bit thin and strighten up pretty quickly on heavy braid and a stiff rod, so you need to be aware of that. Besides that though, this will be my go to light tackle saltwater lure.
Marshie
Hi Tony,
The top dogs are made by Mirrolure.  I got mine direct(http://www.mirrolure.com/lumo/index.html) and paid around R35 include VAT, clearance and postage about 2 years ago.  At that stage they were selling for R75 in our local stores.
Most tackle shops in the Eastern Cape stock Chisel plugs.  I find the predator range to be very versatile.  The Alcock's will be able to hook you up - contact them on 041 365 6868.
Marshie
