9ft Spinning rod for the Surf
Pieter Immelman wrote:
[ build would weigh in at around 265gr total weight.
How far do can you cast with this rod and say a 2-3 oz casting weight?
Thanks.
PI[/quote]
I will have to finish a preliminary build and then go cast on the casting field to get accurate measurements.
Casting just a weight will be 130m minimum on 30lbs as we get up to 150m on the 10'6" (measured)
Casting lures obviously makes a huge difference although this rod due to it's tip action is very forgiving and I seldom get lures tumbling in the cast.
I'm going to build this rod mean and slim and try keep it under 275gr total build weight.
Vades
Spoedvraat wrote:
Vades wrote:
Spoedvraat wrote:
Is it the new Rovex D Alcock Signature series?
No, totally different rod (I have one of those too).
How does the weight of this compare to your Graphcast? Casting weight of the Rovex is a limiting factor,nice rod though
Rod weight?
My Rovex is lighter as it's a 7'6" compared to my 9'6" Graph 3. Also, I use a Stradic 4000 on the Rovex and a Saragosa 6000 on the Graph.
Different setups for different applications.
To add, the Rovex tip has a quicker action.
Spoedvraat
I've got the 9ft Rovex that is rated at 1.5oz.
Was wanting to compare rod alone weights of the 9ft Graphcast and the 9ft Rovex seen as I'll be using the same reel.I'll compare the weight with what Enigma stated
Al
Dave Alcock also builds a 10' custom rod which I use with a 6000 Shimano Stradic which is designed for 1 1/2 oz and will throw a bit heavier lures.
His 9' and 10' are both great rods and good value.
There are many cheaper rods out there but in my experience you "get what you pay for".
The Alcocks have a lot of leadhead fishing knowledge which they have used in their rod designs. Great rods.
