7/0 circles
Tope
Hi im looking for some decent 7/0 circle hooks what do you guys recomend, i have been useing 5/0 circles but i would like to try 7/0
 thanks tope
I like the Z-Steel and fish all fish with them but I have had great results using the Eagler Claw range with the Sailfish (thinner gauge for edibles) and the Sport (heavy guage for In-eds)
The Eagle claw are really well priced and do the job well and shopuld be way more readily available now that Sensation has taken over their sales and distribution
Blackpylie
Ive noticed the VMC circles are a bit on the  heavy side, and when fishing for live baits, it might kill your live bait quicker than the lighter mustads. my thoughts
Blackpylie
Hey Craig I replied on the 1000th post, Post.
From what i can say im very impressed with the rod, took it for a outing two days ago, casts like a dream, but ill definitely have to practice loading the short heavy tip properly, as its stiffer than i what i initially thought. Its perfect for swimbaits though!.
I fished at Silversands for spottys and lost a big one in the drop off, in terms of pulling power, its a beast.
My only concern now is getting carontex washers fitted, have called 5 people, of which everyone is waiting.just waiting for stilbaai, have to unfortunately work till the 15th. will report back after the vacs
I already have two people interested in having rods made for them. and gave your contact details. if it fine
cheers
  • Full_Rod_with_Short_heavy_tip_-_siverbind_for_night_fishing_and_Extra_tip.jpg
Blackpylie
Geez just realized i totally hijacked your post, sorry dude
fishersteve1972
Hi Tope,if you are in the UK- VEALS mail order have the varivas circle hook up to 8/0 @ £5.80 / 10.I use some of the smaller sizes which do the business.
TOE 007
what are you talking about ?
 VMC are the best circles ..... mustad the light er gauge hooks are VERY scarce , VMC , and OWNER !!!!!!
TOE 007
The VMC hooks are one of the best eds hooks you can fish , i only fish with vmc , owner circles , yes the VMC are light gauge hooks but , be honest , noting is gonna open that hook open , on the eds front , i have caught yellowtail offshore with them , for eds in Falsebay i fish the 0/6 sometimes with a skellem hook [bass hook ] above my float ...
the Mustads are to heavy for eds , i tend to bend them open a bit more if i have to fish with them ... but in my opinion you dont need such a heavy hook .....
Tope
Yes i go on there cant say ive seen the 8/0s, at the moment im using Tournament Circles -E7385 50 5/0 £12.57
but im failing to hook-up with these as the eagle claw, so i thought of going slightly larger ie 7/0
but maybe i should shed light on what im using them for the rig is a limited pully 80lbs rig body,  40lbs 18" hook lenght with a snelled circle hook on the bottom and a size 1/0 eagle claw above just to hold the longer baits, and a 175g plain lead
bait is either 5-6 mussel`s or 2-3 yellowtail worms  some say you cant use circles with worm ya can with a modifide bait needle,
and the fish im targating are cod (gadus)
tope
fishersteve1972
Hi Tope
I dont fish for cod here in Jersey but I do love to buy it with chips.I noticed you mentioned you using a pulley rig with plain sinker.If your rod is in a stand try a gripaway lead or breakaway impact lead as this method allows fish to hook them selves.If you are holding your rod give the normal J hook or semi circle hook a bash.I prefer to use a circle hook with bait such as live sandeel or mackeral head where you can hook it through the jaw and the hook point stands proud and does the business.
Failing that try the chippy,1 cod and chips please.
Tope
Hi Tope
LOL jersey home of the bass you lucky sod,
i do free line with mackeral heads or blueys and had had good results, as for using grip leads i dont like using them on rocks loose to many bad enough with the plain leads,
And weve just had cod`n`chips  for tea from my last seasion using eagle claws,
tope
BigBass
Cod have big mouths and probably feed similarly to our kob/ kabeljou (drum in North America), so a 7/0 or 8/0 Circle hook would be the way to go. I am partial to Gamakatsus. This works great with the Pulley Rig ... Just remember to keep the point and gape of the hook well open and don't strike!
Tope
Cheers BB i normally whip the bait on a bait needle then sit the circle on top so it has total exposure, i have just ordered 50 vmc sports to go at, if no good ill have found some eagle claw 8/0
tope
Nepptune
I'm with BB, you can't go wrong with Gamakatsu's... Owner also make awesome heavy duty Circles, but for light applications, Demon Claw are wicked...
