Brilliant idea John.
I have this problem at my cottage on the KZN-coast all the time. I just dont have a spot to cement it in permanently,but I have a plan that might solve that.
If you use a small dollop of marine silicone on every pvc joint it would make the whole thing fairly waterproof.If you then fill it with water via any one of the vertical pipes,just until the base is filled level,it should have enough weight to keep your rods in the vertical position without falling over.And after my fishing trip I can simply empty it by flipping it over to discard the water, and store it in my garage again, until next time.
p.s Maybe Mark Shuttleworth can work out the volume, using the specs for the piping that you shared and then convert the water capacity to Kilograms,1/1. ,LOL
