2 Questions
Def-e-nition
Morning Chaps .
 if anyone has some original/creative ways (pics maybe ?) besides toothpicks , of clipping baits for getting further distance without it ending halway up the snoot cuz of a broken toothpick , i'd welcome anything that anyone can throw this Way .
 been using 8 oz now for throws , and in comps my baits Are getting biekah and biekah  , and perhaps a Little More sloppy as Well , resulting in missed oppurtunities due to the bait being up One alley , and the hook up another !!
alternatively , if you're throwing heads without clipping - What distance are we Losing , as I have thrown circles clipped , the sinker though invariably lies right Next to the tail head . i do find that sometimes the force of The head hitting the water sometimes breaks it Free to A Degree , and it either slides off the point of the hook -which does have a cable tie on  , or over the knot - back up the snoot .
 Nou toe - This time i'm Needing some advice .
Kom Manne kom ! Put yer thinking caps On and post me some Advcie !
Thanks in Advance .
Def .
kopstamp
HI stu, cant help with excactly how much distance one looses, but been learing with my eyes and ears from the Oom.
Instead of toothpicks, use bamboo, readily available in the form of chopsticks or an uxpecting neighbour or most nursesaries. It can be shaped but it is very strong.
The circle part, enigma has been using the method where he sows the head to the hook, there is no chance of slipping up the line or hook point.
In the rock surf and deep two months back there is a clear photo of this, or check the "the pier is wild " thread, pics of that method there aswell.
Hope it helps
mark norval
Use a needle with plastic head, will never break!!!
Distance as I have heard is 30-40m.
But then again I know nothing about fishing so I could be wrong!
Stu we must make a gooi over december:fishn
Def-e-nition
Hope it helps
good idea there .
 wessel - sowing the head on In comps isn't gonna Look too good for My Image , sittign with a needle n thread on the beach .........
Pylstert
shop around, you get bamboo toothpics, sometimes you loose distance clipping if your bait is not aerodynamic it propellers, best to leave it unclipped then
Def-e-nition
Dun-dun dun-dun ...............................
dun-dun dun-dun-dun-dun-dun-dun ......
The eeriest Cello Piece I've ever heard ...............!!
FLUKE
I personally don't think it's possible to clip a circle hook.
If you bridle rig your bait which imo is the only way with a circle then your bait ends up below the sinker which defeats the object of clipping it.
I do not clip with a circle hook but I do pay attention to the shape of my bait.
Personally I doubt if you loose more than 5-10% distance depending on size of bait and wind direction.
Do like the Marlin guys do by pre tying the floss loop to the baits.
I will take a few pics of something I picked up from a few KZN boys throwing baits on circles and keeping the bait out of the wires of the grapnel.
Part of the problem when clipping on a circle is that the bait lays low on the weight and the wires of the grapnel pus it to the side making completely non aerodynamic
In essence it allows the bait to be above the weight and in line instead of being pushed off to one side.
As for heads, a head like a shad head if cut correctly casts better unclipped than clipped as it is hydrodynamic, therefore aerodynamic and it flies stably alongside the weight
First saw this when demonstrated by Floors Marais of Southern Cape and recently in PE when watching how far a Carranteen can be cast unclipped (if hooked correctly)
Loss of distance can be up to 50% if the bait is not aerodynamic and spins and flails in the air when cast
kopstamp
Haha, hell saturday was so slow, i would have not looked funny at a guy even if he was playing cards on his baitboxs....
My biggest improvement came by scalling down on my reel and line.
BUt as enigma suggests,the loop made by pre stiching can just be put onto the hook and pulled shut once on.
Def-e-nition
Correct. Especially head baits .
 i then used a sinker with a much much longer boom , as in The Ones i have Made custom for Me , for sliding  , which puts the bait clear of the grapnels' wires .This however stil doesn't prevent helicopte effect so prevalent to this type of bait .
 And That is precisely what I am trying to prevent . it Is uncomfortable and unnerving standing next to a Giant like hannes botha , while he stands having a conversation and Whacking a head bait out further than i can Wade .......
The answer - check carefully at the base of the strepie throwbait
http://www.sealine.co.za/view_topic.php?id=67015&forum_id=1&page=2
