PIRATEofSTRUISBAAI
Hi Sealiners.
I have a small duck, but the valves are sissing air out of them and needs replacement. Has any of you replaced these before.
I can see there is a tool of some sort to remove the valve, which i do not have. I am planing on replacing it with different New valves. So here's my actual questions and concern.
If I remove the old valve by cutting it... and the new valve is slightly bigger in diameter, can i just cut the hole in the pvc slightly bigger with a scissor?
What is the correct way of removing the old valve without the correct tool? Looks like there is about 2 parts that might thread into each other. Outer one a right hand thread and the inner one left hand thread?
Otherwise I'm just Going to cut the old ones out and hope for the best...
