Wire on a spoon.
Kumz
On 2 of my spoons i do have a small bit or wire quiet similar to a bite trace ... Works for me !!!
Homie
Its always a good idea, but 1.2mm leader will work. remember, the spoon itself acts as a bite trace
Marthin
Unless u hook a bus elf, u should be ok as they tend to take the back en of the spoon.
That being said at Kleinbrak i've seen twice half a decent size elf come out cut clean down the middle, and could only be one of these 4 - 7kg elf like the one caught in langebaan a while ago, and they could take the whole spoon in the mouth. If you are going to use it make ur own one in thin wire, with a smaller clip on swivel, not the cheap snapbacks but the one that clips around. you can get away with a smaller swivel for more strength.
Kumz
I use wire ... cos i use 2 hooks .. 1 on top & other on bottom ..
In transkei ..i lost 2 spoons cos shad went for top hook & chowed through my leader ..
I use the Bleeding Leader wire on my spoons ...
Marthin
i like the teflon coated black, i knot it better, and the finish is neat. 10cm, swivel at the top, clip on at the bottom, makes lure changing a breaze.
neilg
The only time I will attempt to use wire is the day I get bitten off on a spoon or an artificial lure
till this day it has not happened
I have tried it before and caught much less shad, the minute I went back to clear mono the success rate went up again
itsarap
i agree with neilg
i don't use wire or thick leader just my plain leader for when i catch shad off the rocks.
has worked for me in last three years of catching shad on a spoon never bitten off.
ignoblis
@ neilg - Bro I have never used steel either or been bitten off but recently have been considering wire for that bus of a shad I am going to be catching over the week end( Positive thinking). My Question is when you say that you have not been bitten off and considering that in PE you guys generally get Shad/Elf bigger than we do in Durban, what is is you presonal best Shad/Elf.
I am trying to work out how big the fish needs to be before they will bite me off while spinning.
ignoblis
itsarap
hi ignoblis
i know you aimed at neilg but i can tell you that my personal best shad is 1.89 kg and it was on a spoon with plain leader, and the shad get big where we fish to give you an idea they called the spot after the fish, the guys catch ever day there about and the blue shad have only recently come out with the biggest being 3+ kg
ignoblis
Thanks Mate
I personally have caught a 3 Kg Shad with a 20Pound Fluoro leader and no problem the leader was not even worn at all.But have heard of 5Kg+ Shad coming out at the moment. That is what I talking about. Do I need wire for this size fish or not.
ignoblis
itsarap
if it was me fishing for that size shad i would stick to my original method of throwing spoon but if and thats a big if it bites me off then I'll think off putting on a wire only then. Its safe to say that shad like to strike the tail first before they hit the rest of the fish.
neilg
I never measured or weighed the elf, but it was in the 2.5-3.5kg range, caught off the boat.
I was using my favourite Purple Onda Onda
I was using a 7ft Elbe rod, 3000 Exceller Plus reel , about 5kg fireline and 5kg Fluorocarbon.
The next fish I caught (after that one) was atleast 1kg heavier, but broke the leader knot RIGHT RIGHT NEXT to the boat.
So I lost that one with my lure.
I know I always make a long story, but I learnt a valuable lesson that day, doesn't matter how good you make your knots, always check them after every few fish, which is something I didn't do on the day, I was just having too much fun. That day I caught probably about 70 elf, with most of them being between the 1.5 and 2.5kg range.
After the motha of them all broke me off, well I was heartbroken cause I only had the one purple onda. I caught a few more on the green and also the clear one, but not nearly as good a hookup rate as on the purple.
Marthin
When my father in law caught his bus in langebaan, the spoon caught the fish on the outside of the jaw, more on the cheek. Now this is where u might get problems if the hook is on the outside of the right cheek, and the fish is facing u and swimming to your left. The line will go through it's mouth when opened, when shut it clamps down... 4.5kg shad a gonner!!!. He had a 15cm cheap clip on trace on, and the plastic covering over the wire took a serious hiding. I'm in doubt he would have lost that fish if he wasnt fishing a wire trace.
neilg
Marthin
was your father (my hero) fishing a treble hook or a single j-hook ?
I found I got alot of outside the mouth hookups when I still used Triangle Hooks
With the j-Hook 99% of my hookups have been in the mouth, leaving a smaller ELF biting on the hook and a big elf biting on the back of the lure
Also remember, MOST OF THE TIME elf attack from the back (agter die kop kykers haha) so they really have to swallow the MOVING lure to get to your mono line ...
Marthin
Yip it was a treble. I changed the back hook on my rapalas to single and kept the front a treble. After i saw what damage the treble did to the cheek and how nearly it tore out, J's is a much safer bet.
Also we were trolling the lures behind the boat, and if you are trolling too fast sometimes the fish hit the side of the bait in stead of being able to "engulf" it from the back.
Made a few possible jigs for the dropshot. Bandit have an exeptionally long long shank hook. Could get the hook much closer to the end of the anchovie dropshot.
