Winter Yellows
DWB
Ok, so since i got my boat more than a month ago, i haven't landed a single fish from it. So yesterday after checking out the weather me and my buddy Llewellyn decided that we'll shoot through to Morgenstond dam to go and target some winter yellows.
Quickly hooked the boat, packed the gear and off we went, after trying out a new road and getting seriously lost, we got to the water around 14h15.
Only to have some papgooiers put their whole shebang in the middle of the public launch, vispenne the works. So we had to launch by hand and in some dodgy place aswell.
First went through the mental checklist, boat plugs, batteries etc etc.
Put the boat on the water, warm up the engine, tie on lures and off we go.
Heading for our favorite Mteri Lookalike spot first....
Fished around the trees for quite some time and finally getting the colour pattern right, Llewellyn landed his first on spinner, about 750g
Soon after changing to the right colour, i also landed one of 600g.
Then we decided to head to another secret spot.....
This is where my fun started:
Something slams my lure hard!!!!
1.3kg Yellow
Beautiful fish, and unfortunately i make it look small...
And then another one of 1.2kg....HMMMMM
No bass can fight like these
@ Carla, notice there is a lure in its mouth
Ryan
Congrats
@ Carla he just hung the "RAPALA" in that fishes mouth.
Check the bucket of Mielies Lewelyn in sitting on.......
Mozi
Dit maak my nou baie lus ... Watter kleur kunsaas is dit toe wat gewerk het vir julle Deon ?
Halco of Rapala ?
DWB
Daar is net een Halco in my boks, ek het hom gewen, anders het ek hom nie gehad nie.........
Mozi
Goed om te weet Deon . Ek kry ook nou die Salmo's, eks regtig beindruk.
Ryan,
Can you maby give me a description of the salmo lures and colours that works well for yellows ; barble and Kurper... ? :fswim
Ryan
Mozi check out the artlure section there are a whole herd of sticky's at the top of the forum here you will find all the info you require.......;)
MAN
Jiiiiiiiiinnnnnnneeee manne maar dit is omtrent n klop nice visse wat julle daar gevang het!
Well done met mooi vangste lyk of julle nou die SPOT gekry het,dit lyk omtrent soos Mteri daai!
Carla VdW
:merm
Hi there Deon and Ryan and the rest of the crew.
Computer specialists are the pits I've seen beter speciallists in Gov Hospitals and after having to wait what seemed forever for my computer to be fixed after some kind of destructive virus infected the thing and having to pay an exorbatant price to have it removed I am back
My Jozini trip was cancelled due to the doctors strike that was going on as you know and that was even worse than pc problems :X
So Deon those are nice yellows you have there pitty about not being able to hide the bait box that doesnt fit under L's rear end.
Deon hanging lure's in a fishes mouth is as good as tipping the hooks with maggots you know :whisp
Morgies must be coming on bout now or what if you can get them there ;)
All funny biz aside howz the barbel quest going there anny luck
Carls
:merm
Carla VdW
:merm
@ Bass Mad
The yellows found in Morgenstond are Smallscale yellowfish (Barbus polylepis)
The fishing with lures is done in a similar fasion as for bass but smaller lures are mainly used here for these beauties.
Small silver DAM spinners and Rapala F5 in silver and gold are the good producers together with the Salmo hornet range (Ryan will be able to give more details on them)
They can often be found close to structure like submerged rocks and stands of trees on reeds where they hunt small baitfish and other prey, during the more active times of the year they cruise all allong the rocky edges of the dam and frequenting the outside edge's of weed beds is also a favourite haunt for them too.
Experiment with the retrieve ratio and as soon as you find what they want and how they want it, have fun.
Btw a Mrs Simpson tied on a #4 - 2 hook and cast out on a intermediate line with a steady retrieve all along the weed edges is deadly
Great fun to catch
:sf:::
Bass mad
Hi Carla,
Gave it a try last week end in the gamka river, but alas no luck, water very cold. Will keep giving it a bash as it warms up. Cant wait to get one believe they give a great fight
Carla VdW
:merm
Bass mad
Okay river fishing I thought you were fishing a stillwater for them. River fishing during the colder months for Yellows can be great fun and very productive, Oliver and I often used to fish for them during the colder months of winter in the Assegai and Pongola rivers that flow nearby his home town Piet Retief.
We mostly used fly fishing gear, "Horst Filter" style using a floating line, long leader and small flies such as Mustard Caddis, SS Shrimp, Bloodworms and Oliver also had two flies that were pretty productive especially in the Assegai. We would cast across the larger pools as close as possible to the reeds on the opposite bank and let the flies drift downstream imparting a twitch or two every now and then often the strike would come as the flies sank after the twitch, catching Small-scale and Large scales to our hearts content.
The trick is to locate the fish, on arrival beside the water be quiet and scan the water carefully in the larger pools a fish might rise to some insect that has fallen on the water’s surface, or the silver or golden flash of a turning fish in faster water where the fish hold waiting for a juicy morsel to drift by on the current, will be the giveaway. Move quietly and try not to wade if possible (not advisable in winter) and before moving from one spot to another scan the water carefully, yellows will spot you and disappear in a flash, a pair of Polaroid sunnies are not a accessory here but an essential requirement. In the larger and deeper pools the fish often congregate baking just like carp also do in the lazy winter’s afternoon sun. Once you have located the fish you can be sure that unless due to major changes in the rivers course or flow, they can nearly always be found there again in the following seasons to come.
In the larger pools start by working from where the water flows out of the pool into the next pool or run, cast upstream into the pool and work the lure back just faster than the current to give it action, a erratic swimming action often does the trick, make your first cast tight to the bank closest to you and be prepared for your lure to get stuck and then suddenly start moving of as the fish feels the bite of the hooks, keep fan casting over the water until you are casting straight down the current tight against the structure closest to you retrieving directly upstream, often yellows will hold on the downstream side of rocks and other structure staying out of the main current waiting for a morsel to drift by and pounce on it.
If no success move upstream and cast into the next pool once again make your first cast tight against the near side structure unless you can see a fish visibly and actively feeding ahead of you, fan cast over the pool covering all the likely spots until you are casting downstream again, you will soon come to recognize these as your success increases. Just before moving on make a few more casts again upstream often while working the downstream lies a patrolling yellow might have heard the lures splash as it fell in the water and has come over to investigate, cast out and let the lure sit if it’s a floating lure, giving the fish time to locate it before commencing your retrieve.
In the larger pools look for the fish that congregate to sunbathe, sight cast to the fish that in two’s and three’s separate from the shoal, these are often fish that are in search of something to eat and will pounce on a well placed lure, wait until they are a few meters from the main shoal, this way if you do pick up a fish its struggles wont put down the whole school and allow you to make another cast or two. I suggest you avoid these fish after the first rains have come, as shortly after the heavy rains have come, they go into spawning mode and don’t need to be disturbed, they are just a too precious and leaving them ensures next year’s great fishing.
Often in clear conditions submerged boulders are visible take the time to watch these hotspots, it will be worth your time, yellows love to cruise from boulder to boulder in a trout like beat searching for meals that hang out near such structure, once you have located the fish follow its beat from rock to rock, once you can anticipate the direction the fish is swimming make your cast towards the fish and be assured that it will eagerly accept your offering, these fish are often territorial and usually the “papa” of the pool who will chase other intruders of their beat.
Where water spills into a pool it washes sand into it the sand that forms a bank that often suddenly drops off steeply into the deeper water of the pool, if you can see the edge of this so called drop of try to make a few casts over it or along it, often more than one yellow will just hang in the deeper waters below the rim waiting for small creatures to be washed over the rim (Finding Nemo way) and become easy pickings in the confusion of the turbulence created by the wash of the current.
Hope this helps you to find them yellows in the winter, once you know where the favorite hangouts are and learn to recognize the likely lies you your success rate will increase, in time you will be able to apply this knowledge to most other river systems with confidence.
Good luck and persevere it will pay off
Tight lines
Carls
:sf:::
