will any one help me on techniques to improve my c
Oom G
Bought myself 2 new Sensation Explosions and got 130m with a M3 with Bol on easyyyy.... I've gone down to M2 and the distance stayed basically the same.... Fished with .21 double XX and 17lb leader....Overhead cast....
Naruto
Save just a little bit more and invest in the Sensation Rockets at around R800 each. Just bare in mind that these rods do need to be loaded properly to get more distance. P3 up to a P5 or a M1.5 or M2 with small bomb. Many of these stiffer rods are bit difficult to get used to but its worth it. Won our zone yesterday due to the fact that I could cast further on the day than the guy next to me.and with the guides fitted those rods you won't be casting off..
Bottie
I agree wholeheartedly. Die Rockets gooi soos 'n bom (pardon the pun), en hulle speel 'n vis ook nie te onaardig nie, behalwe as hy nog baie klein is.
StefS
As mentioned on another thread, I settled on the Sensation Demon (3.5lbs test curve) almost leans toward the specimen rod side but I like that it is not as stiff as the Thunderbolt which has a 4lbs curve IIRC. I might look at Rockets for my 2nd rod.
I mostly use the gly rietvlei with an M1.5 and egg size bomb. Currently 12lbs mailine (couldn't get 10lbs) with 17lbs leader. Will switch to 5 or 7 lbs once I'm back into the swing of things again. I think I get about 80m currently but not sure how accurate my judgement is.
JohanZ1000
Hi you all,i am new to the seen,i bought my self two 12' sensation rockets and shimano 10000 baitrunners filled with .30 mm 11.9 kg ION power browny carp line.
only went fishing twice with them so far,still need to get the hang of the stiffness of the rods,
You all talk about P1,P2 and so on,what does this mean in grams
Gertus
GregB1 wrote:
Try price the new Sensation Rocket not sure how much they go for but i know people are getting good distance with them.
Hell yea.. got 12 fts i LOOVE them..
@ a budget of 700 per rod .. you will not get better(in my humble oppinion) than the Rockets..
Change to a 17lb leader and 7lb line...
Every day i go fishing I try and discover something new.. that is why we PRACTICE.. it is a question of trial and error..
just this weekend i changed my grip and where i lay my line on my finger and voila..
as in golf looking at your target helps...
my 2c.
fishing at rooivalle this weeknd so every meter will help..
Looking at your target is fine but to get distance don't look at the target on the water as that will generally result in to short a cast
Determine your direction by means of a far aiming point ie a telephone pole on the other side of the dam.
Then aim at an imaginary point 50 degrees above that target so that you are trying to hit is in the heavens above the horizon, this will add at least 20% distance to a cast where you aim at the water.
Good news however is that the fish are in the flats at Rooiwalle and those fishing 60m on a kol throughout the day been getting the best bags in terms of numbers.
As with any venue on the Vaal, start with one bait at 60m and the other flat out and observe the venue for the first hour to get an idea of what is going on before changing baits etc (obviously if the rest of the bank is 10 min per angler per fish then change) but if it's a fish now and then per diff angler wait it out and don't pull your bait out from under the nose of a possible catch
Gertus
as in golf looking at your target[forgot to mention target on the waters egde as aposed to looking at your bait as you cast... e.g. telephone pole,tree,bird,chick on boat was it not 51% above.. im confused.. ] helps... FIXED!!!
my 2c.
fishing at rooivalle this weeknd so every meter will help..[i missed the big flats of rooivalle i guess streetmaps did not show all this information... but again i wrongly assumed anyone can cast 60 in the morning .. its when the fish are deep that you need to get out there.. but im sure we all knew that too..] FIXED !
there will always be a one up who will correct others comments ...
supa-m
ek het die naweek met n ander oom se shmano beastmasters gehengel so toe maak ek my bom aan toe is dit te slap en ek gooi dit die heeltyd af en ek besluit toe om n p4 op toe sit en toe sit ek alles in wat ek het en toe het ek amper hier by die 130 m gegooi teen die wind so daai is lekker stokke so toe se hy vir my as ek my kant bring en ek vat die juniors in die klub komps dan sal hy my R300 gee e as ek volgende jaar goed doen dan sal hy my borg hy gee die helfte en ek gee die ander helfte of so iets . so ek gaan vir my beastmasters koop wat dink julle daarvan
Naruto
Klink soos n goeie plan daai!
supa-m
ja en ek gaan spaar vir die stokke en dan gaan ek ook vir my n nuwe kas en stainlessteel satand koop baie leker kas en stand daai
