when sliding a yellowtail head and using a circle
Vuilhond
when sliding a yellowtail head and using a circle hook,is it better to use two circles, or will one hook through the mouth suiffice?surely using 2 hooks will give you a better chance?
Vuilhond
ive read that when using circles only one hook is needed and a second circle wont improve your strkie rate
If you want to catch the small fish that plays with the bait then I fish a J Hook on the bottom (10/0) and a circle that I bridle to the bait with a cable tie through the lips (16-20/0).
But if you're out for big fish with big baits then only a single hook. Haven't had my bait stolen with a single hook and seldom get throat or gut hookups with a single hook
As a matter of fact even with the double don't get gut hooked fish with the J or Circle.
Caught 2 raggies with this single bait with single circle. Let him swallow, tighten up and when he's on good and proper crank up and work the hook through
I caught 2 x Raggies and got stripped by something huge ...... on this Hound head rigged on a circle and J Hook.
My typical single circle rigs that I use with my European clients, When you hook a shark on this the only way he gets way is if he strips your reel or cuts you off on a reef
