what type spray gun
belindau
Need some advice on spray gun. Purchased a 24l compressor for diy work at home. Will a low presssure high volume gun work for this compressor or better to get low pressure low volume gun. Thanks
Limpopoking
I use the HVLP guns but I'm not very good with a gun. I used to buy high end guns like Sagola and de Vilbiss but now I buy the cheapest I can. I also prefer gravity fed (cup upside down on top). I generally spray at less than a bar but it depends on the product.
belindau
Thanks. Looks if this compressor will be able to run with hvlp. Will just make sure on gun specification. May just as well pay extra to go for the lvlp as they use much less air as i understand. What size compressor do you run?
Limpopoking
In my personal workshop I have a 24l from Matus. I seem to remember that LVLP doesn't atomise as well as HVLP. Either way, your comp will be more than able to run any hobby gun. It's when you get to the air hungry applications like grinders and breakers that small comps can't keep up. If I were you, I'd go buy a R150 Air Craft or one of the cheapies they sell at Adendorfs. If you find you're really into it and want to start getting expressive with it, then get yourself a clever gun.
Biggest thing is gun cleanliness. I use lots of 200 thinners immediately after a spray job and get it spotless. All my previous guns have been written off because of cleaning issues following use by my staff. My most recent cheapie has been in use for about 3 years and looks like it's still new. Only the plastic cup shows a slight green tinge because of a big QD Green job I did.
