It stands for high modulous carbon ie graphite ........it however comes in different formats commonly used for rods normally 36 ton-40 ton-42 ton- 46 ton mainly used in the manufacture of rods with proporlene wrappings added to give it strength. The higher the tonnage goes the greater the tensile strength of the carbon becomes but so does the brittleness,Please note that some rod manufacurers use modulous to advertise ie IM 7+8+9+10+12 and so on take care here as there is no standard for this so putting im12 in ensence does not mean much at all. There are many loosely used terms such as HMG HMC and so it goes on all are howwever very simply graiphte ie carbonfibre. Most rods aremade from 24 ton carbon in pure form with good resin this is actually very good the HMG is lighter in pure form and stiffer as well both have pros and cons T24 is stronger and bend more HMG i slighter stiffer stronger but does not like bending beyond 35-45% is then breaks at the tensile fail point is reached but you need to pull much harder than on the t24 in the same wrapp. I have foudn the best blend is when the t24 and t53 are mixed from top to bottom throught the blank IE one wrapp t24 versus 1 wrapp t53 it works great my best rods were made like this by blue marlin. then i have an old 400-3 and 400-4 even though its normal carbon its very stiff indeed but garth has some secrets there he keeps to himself ...SMILE they make some really awsome rods too i think stil the best the ones the offer resistance and ionly tip action. Dont think HMG i salways the best try it see if you like it. Many folks cannot bend the rods and try the high off the ground cast which they think is a pendulum but is not not even a fishing pendulum but the arialised groud cast in fact. Our HMG rods are not designed to load with this kind of cast at all you will note the pendulum rods have a relativley soft tip but the base has loads and loads of power in reserve as this is what give the distance nd power in a true pendulum not the tip but base the tip only controlls the lead
Hopefully this short discription wil help and add some value to the question. Thankx
