Weekend fishing
afghan
Went on my first proper boat trip in the harbour. Used white crackers as bait. From all the reports over the past few weeks i decided to carry a 10kg rice bag for all the fish i was expecting.
After 4 hours of fishing on a incoming spring tide, i got just one nibble, effectively a half cracker bitten off and between 9 guys only 2 undersize grunters were landed and released.
So far i've managed four fishing trips in the past 3 months and one blacktail to show for it. Any good muti for this bad luck.Anywz hope u guys did better.
salty
shot for the report. my advice to you if you going specifically for grunter in the harbour is, go on a spring tide (from 2 days before to 5 days after) on the next incoming after a very hot day.if the water is very murky use red eye or sardine fillet and if the water is clean use cracker. the lighter the equipment = more bites.
hope it made sense.
afghan
Shot for the advice salty.
Got myself a 7foot elbe dropshot rod for harbour fishing, but the way its going, even a toby will make me happy.
mr zipozn
Howzit also fished the bay sunday morning had live ginger shrimp, cracker and glassy's and only one pull = under size grunter it was dead think the water was to cold.
afghan
i did notice that the water was cold but i thought that it maters very little when fishing in the harbour or estuary. Where are the experts?
killer fish
3.6kg , 8 pound line 3 n a quater inch KP , 5weight fly rod to experience the true fighting capabilites of any fish in the Durban harbour. Yip you will lose some fish on this tackle , but eish we have to give the fish a chance as well. Biggest fish landed on this sort of outfit was a 11kg cob back in Dec 1987.
Remember the law of averages particularly when fishing in estuaries for the eds , You can catch a big fish on a small hook but you cant catch a small fish on a big hook. No 6 hook to a no 1 hook for the grunters. No 1 to a 5/0 for fish such as Cob and Garrick.
Go for slightly heavier rod and reel combos when targeting a Garrick or Kingie KEEP to the 3,6kg line spec for LTB angling, it adds to the fun.
Killer
fished the harbour on saturday and sunday. over the two days managed to land 20 fish between the 6 of us. kept 2 grunter and 4 sole the rest where undersize and released.
The long , thin fish weighed in @ 1.2 kg .
Caught on ginger , 2hrs before high tide using the "walking" trace.
The short , fat one weighed in @ 1.1 kg.
Caught sardine fillet , 30 mins before high tide using light tackle grunter trace.
Hi , Mr Zipozn
Following is what I refer to as a "Walking trace ". ( Others may be referring to it by some other name ).
1. 1st eye of 3 way swivel : tie your mainline to this eye.
2. 2nd eye of 3 way swivel : tie a +- 65cm trace line to this eye. I then tie a 1/O hook to the end of this line.
3. 3rd eye of 3 way swivel : tie a +- 75cm running sinker line to this eye. I slide a 1/4 ounce ball sinker onto this line with a bead on either side of the sinker.
4. Now tie the other end of the sinker line to a 2 way swivel.
5. From the other eye of the 2 way swivel , tie a +- 65cm trace line to this eye. I then tie a 1/O hook to the end of this line.
The above trace lengths , hook size and sinker weight is what worked for me.
Hope this is easily understood and helpful.
All the best.
mr zipozn
I've also notice fishing is better when the water's warmer.guys what about which wind is better for which spots in the bay?
afghan
Thanks guys for informative replies.
@ Fishfearman, were u on a boat and where about in the harbour did u catch them.
Good going
Hi Afghan
Yes , I was of a boat.
Saturday : got some action along the bank opposite Wilson Wharf.  Moved along that bank between Yacht Moor and Wilson Wharf. Lost one which can aptly be described as a  " speed boat "..........................Kids rod was bent over the side with the tip literally in the water , when I noticed it. Ratchet wasn't running as yet. So I run , grab and hit simultaneously  ( No , I'm no acrobat ! ) . The fish took of like it was on steroids. Tried to turn it by applying a bit of pressure .....but to no avail. Gave my son the rod  to " play " it...............he let it run whilst applying pressure at the same time. Fish was literally peeling out line in knots ( OK , I exaggerate a bit ....let's settle on kilometers ) and then the line went slack.............mainline / swivel knot opened up ! Doctor has advised him to now have a weeks rest to recover from the depression !
Sunday : the above area , after a couple of hours , produced zero bites so we then drifted for couple of hours ,  starting opposite coaling dump , also no bites. Eventually got some action on center bank directly across Yacht Moor , between the Red buoy and White buoy............this was our last stop on our way out. Luck !
Sunday was hard work. No bites , not even nibbles, for most of the morning. Lots of moving  around trying to find the fish.
All the best.
robmad
fishfearman,you say you caught one on ginger,what bait is that and how do you put it on the hook?
Hi Robmad
I thread my hook through its body and exit just before the head. However , many prefer to just hook the tail as it allows the ginger shrimp to still move relatively freely.
Ginger shrimps give of a distinctive clicking sound.
Hi Robmad
Here in Durban , there are a couple of gentleman who have permits to push for them.
They normally push for the ginger shrimps during low and incoming tide at Roundbush or Yacht Mole.
Regards
