Weedless Hooks.
Nam-fish
Good Morning all.
Thought you bass fundies would be able to assist me, although I want to apply this to bream catching in the Kavango River. (I always say that the Nembwe is the "african native bass" since their feeding habits, behaviour, angling methods ect. are almost identical..)
We had inter-club bream trails this past weekend, and the following was apparent:
The bream were holding in heavy cover along the banks of the river (papyrus/reeds/watergrass). Spinnerbaits/Jigs worked OK, since you were able to reach the fish easer due to the snag-free qualities, but was far less effective than a small copper spoon (Effzett). The only setback of the spoons were of course the exposed hooks that hooked into anything and everthing botanical in near vicinity... Once you were able to get that spoon into a hole without snagging, you will almost be certain to have a pull, while the spinnerbait in exactly the same spot wouldn't be as effective. Only problem is, you might only achieve this in 1 out of 20 casts with the spoon, the others would either get stuck, or your treble would be fouled by plant material... very frustrating. Changing the treble to a single hook helped a bit, but not much. Casting just short the vegitation yielded no strikes at all...you had to get into the thick stuff.
Now for my question- what if its possible to make the effzett- spoon weedless?? Maybe attaching some broom brissle to a widegap single hook not unlike the hook on a weedless jig? Or do you get ready-made weedless hooks in the shops? Would this "weedless hooks" influence the action of the spoon?
Any ideas would be much appreciated.
Thanx
Pieter
E-Bird
Hi Pieter
There is weedless hooks available in the shops eagle-claw makes them but is difficult to find.We had the same problem last year at the Zambezi so this upgrading and putting weedless hooks on Effzet spoons to fish heavy cover.
Mustad makes one and it looks like this
s7_112958_imageset_01
this is a more fancy one done by Matzuo
Now I can't see why it cannot work and if DIY'ed like you suggested with the hardened broom bristles tied and epoxied to the shank, you could get what you need done @ a fraction of the cost of trying to import these hooks.
What I'm ultimately saying is that a weedless treble should work without infringing on the action of the lure too much, it's just a matter of experimenting with the ammount of bristles and the tying method.
Nam-fish
@ E-bird : Baie dankie vir die inligting - ek sal bietjie rondsoek - is dalk gedurende Aug in Pta en sal dan daar kom kyk (want hier in Grootfontein kry mens niks en in Windhoek defnitief nie sulke gespesialiseerde goed nie). Enige winkels in Pta wat jy sou voorstel?
@ LGF - Wow! If I can only get my greesy little paws on some of those trebles!!! Guess it's only available overseas? or if one can modify normal trebles... I don't think the broom bristle will work as the shank on a treble is very short- I kind of thin springwire should work better. I'll try some DIY (I have two left hands though....) and see what I can come up with.
Thanx again
