Wake up Minn Kota & Motorguide
Fishton
Why do we pay so much for our trolling motors? Which at the core of it's purpose, thrust / propulsion, is as outdated as the Model-T Ford.
If the Germany based company Torqeedo had to break into the Trolling Motor market, it would be months before companies such as Minn Kota and Motorguide will become a mere distant memory.
Torqeedo's base model, which is the equivalent of a 1hp petrol outboard, has the torque to drive a prop suited for a 20hp!
The tiny base model Torqeedo brush-less / Electronically-commutated motor is so efficient that it can push a craft of up to 1.5 tons, to a speed of nearly 4kph, for up to 8 hours on a battery with a capacity of only 13 Amp hours!
Lets not even start on the controls and prop design.
Like I said, "Wakey Wakey, rise and shine Minn Kota and MotorGuide, it's time to get cracking in the R & D department.
cranky
do you know what price these units go for...i looked into getting one of these for my kickboat a couple of years ago...but at the time the price was way over the top...so i just laughed off the idea...
i could fish dams like inanda and albert falls if i had one of these for my kickboat...only problem...i would need a seat belt...to prevent slipping out the seat on pull off...a 30 lb set on 5 almost pulls out from under you on a kickboat...lucky i am so heavy otherwise i do believe it would be a kodac moment.
Fishton
They are still bloody expensive Ian. But having said that, my 80lb Minn Kota RipTide (saltwater series) with iPilot costs around R23 000.00.
The SA agent is still Whisper Boat Builders in Cape Towm.
