Vacuum Pack Machine
Simen
For the guys wanting to vacuum pack bait, or repack opened bait to keep refrigerated longer, use a normal household vacuum cleaner.
You will need, a vacuum cleaner, plastic bags, 8 to 10mm plastic pipe 300mm long and some cable ties.
Connect the mall plastic pipe to the vacuum cleaner pipe and then place the small pipe in the plastic bag. roll the open end of the plastic bag around the thin pipe and place the cable tie in position. Pull the cable tie as tight as poosible without closing the small pipe.
The cable tie I find works the best but if there is any better method you can think of let me know.
