Using Circle Hooks For Tigerfish
Tommo
When fishing for tiger fish with bait, live or dead, one of the most effective methods is using a circle hook. These hooks ensure a good hookset, and also enable fish to be released in good shape after the fight.
How Circle Hooks Work:
Circle hooks look odd, with the point facing inwards, and for this reason many people are not that keen to try them out. They are designed to hook fish on the way out of the mouth, after the bait has been swallowed, and line tension pulls the hook back out of the mouth from the throat of the fish. The in bent point prevents the hook from hooking the fish in the throat, gills or stomach, but swivels into place and penetrates the fishes jaw as it exits the mouth.
Choosing the right circle hook:
Using the correct circle hook for the job is the first step. I recommend a circle hook that has its point in line with the shank of the hook, as opposed to offset. Also the hook should be strong while being made from a light gauge wire, ensuring  good penetration. The best hooks for the job in my opinion are the VMC Tournament Circle hooks in size 4/0. Others that will also do the job well are Gamakatsu Nautilus circle hooks while Eagle Claw, Mustad and Owner all make good hooks as well, as long as they fit in with the above criteria.
Rigging Circle Hooks:
The best way to rig a circle hook for tiger fishing, is to do so using knottable wire of 40lb. Any Nylon coated or carbon coated wire can be used for this job, as well as uncoated knottable wire. Piano wire is not ideal for use on circle hooks.  The best way to join the hook to the wire is by snelling it on, with the trace coming into the eye of the hook from the point side.
It is best to use quite a long trace for circle hook fishing, so make the length of the wire around 50cm long, with a power swivel attached to the other end.
Baiting circle hooks:
The important thing when baiting a circle hook is to not choke the gape of the hook. For this reason you want the bait to simply hang off the hook, leaving the hook gape open. Live bait can simply be hooked through the top lip and out between the nostrils, while fillets and dead bait should be hooked on similarly, so that the bait hangs from the hook. While this does not look pretty, it is effective. The pic below shows a piece of squid baited on a circle hook. A fish fillet can be put on the same way.
Another option for rigging livebait is to attach a small J-Hook to the circle hook, using soft wire and hook the livebait with the small hook, as illustrated in the pic below:
How to use the circle hook:
The two most important points when using circle hooks are firstly to allow the fish to swallow the bait before attempting to set the hook. The hook and bait need to have been swallowed for it to work. The second important point is not to strike at all, but to allow the line to tighten and the hook to be pulled into place by the line tightening. Striking will most often simply pull the hook and bait out of the fishes mouth, while a gradual tightening of the line will allow the hook to swivel into place naturally. Once the line is tight, and the fish is on, then you can further set the hook by giving the rod a couple of firm nods.
Therefore once the bait has been picked up by a fish you should allow it sufficient time to eat the bait properly while the reel is giving line freely. Once you decide that the bait has been swallowed, then tighten up and only give a couple of firm nods to the rod once the line is properly tight and the fish is pulling hard on the other end. Simple!
By using circle hooks you will seldom gut hook, or throat hook fish, and the chances of your fish surviving the experience is so much better than using any other method of bait fishing. Also, because the hook will not set in the guts, you can allow it to feed a bit longer before deciding to set the hook without concern that it is going to be hooked to deep. This cuts out some of the anxiety of striking too soon which can happen when fishing with conventional J-hooks and not wanting to kill the fish.
jonnyp
Tommo thanks so much for this explanation
I wish I had seen it ages ago to understand how they work and how to use them
suggest this is saved at the top of the pile....
ripplefisher
Great 'how to' write-up Craig, hopefully get more people into using circles for tiger..
Just a brief query; why do you prefer the straight or flush shanks as opposed to the offset shank circle hooks..? I understood for a number of species the offset shank is substanitally better - when in Florida for example when kite fishing for sails, I learnt that offset circle hooks were banned from a number of competitions...due to their effectiveness...!
Perhaps it's not the case with tiger, and species do vary...hence interested to hear your experiences..?
Cheers, RF / Marc.
Tommo
Howdy Mark, The main issue with offset circles is that they can still gut hook, or throat hook a fish, as the point is not totally 'concealed'. I think that may be why they are banned in some comps as well. The inline point almost never hooks into the stomach or throat, it needs to come up against an edge, such as the jaw of a fish, to swivel into position.
ripplefisher
Hey Craig,
Thanks for the clarification - yes, perhaps you are right. I tied up an inline circle hook night before last - I only have 'piano wire' trace currently, so a haywire twist it was, and also only have one type of non-offset circle hook with me currently (Mustad Demon circle 5/0 Extra fine wire) which look OK - anyways, had a good run on saturday, strangely enough I thought it hooked up well, and I had it on for a good few minutes, and when I had it close - not a big fish at about 4 kilo's, it got off - made a mess of the trace - all kinked and what not, not sure it had taken in the side of the jaw looking at the trace..
I will persevere - lost the last seven fish/runs, but then again, I was on a ratio of 2 fish out of every 3 before that, so perhaps things are just evening up..lol..!
I also like the Owner SSW cutting point hooks for livebait - yes, perhaps not as conservation minded, but a decent hook nonetheless..
Cheers, Marc.
aquadementia
great article Tommo, thanks for sharing
I have found offset circle hooks to be prone to foul and gut hooking, and I have lost far too many fish on offset circles to ever go back. I'll stick to inline circles!
often when fishing livebait, hammerhead jnr or mr hound ends up with a hook under the chin or outside the jaw... but with edibles, they are either hooked well or gut hooked. Just my random observation
Not good for fish or angler :fishn
