using bream/kurper as bait
tyrone mclaren
Hi guys
Well I'm new to the baber angling scene but I've got a few questions, hofefully someone can help. Where I fish there is a lot of bream around and in a variety of sizes is it posible to use this as bait, maybe just the head or fillets? I also catch a lot of small bream could you maybe use this on a live bait rig. How would I set up a live bait rig?
Thanks guys
Skuimkop
Tyrone dit sal verseker werk en toe ek jou topic se opskrif lees was die eerste ding wat deur my kop gegaan het 'live bait'. Ek het plenty jare terug Kurpers gebruik as bait - kop en fillets en het redelike sukses met my min kennis toe behaal. In die Kaap is Kurpers nie so volop nie so ek het van dit af weg beweek maar nou dat ek terug is in die land van die hengelaar gaan ek verseker dit weer begin inspan.
Ps: Ek is oppad uit maar sal hopenlik in die week vir jou iets kan stuur hoe ek my live baits op rig. Maar jy weet natuurlik live bait hengel is baie stout, lol.
nobbles
I am a firm believer in trying to use bait that is natural to the dam. If there are bream in the dam and a very good quantity that is what the cats will be feeding on naturaly. So yes they will work, i have tried this with bream myself and have very good results. Oftin its the only bait that gets touched. I have used the heads cut a bit behind the gill plate of 20 cm Bream (i call them ernies at that size). Fillits work as do small whole fish. If you use them as live bait make sure they do not have a spikey dorsal fin, Mr whiskers will bite down feel the spikes and spit it out. Found this out to my irritation while drifting live tilapia through them, float went down float cam up. And on every fish the skin over the spikes was pushed down. If you can cut it open like a carp head and try use the same rigging method. I have gone through so many hook placements now i could kill some one.  But presentation will all deopend on the size of the "ernie". What size have you been getting?
J_Bay
I've used Kurper for barbel many times, and it works at least 80% of the time, they just can't get enough of them!!
I once left a live Kurper out from 12AM to 8PM before I got a run, at Roos se Oord. I can't say for certain it was still alive, but I tried the same thing again 3 weeks later and got another barbel, so I can say that it works!
tyrone mclaren
Thanks a million guys, I'm definitly going to give the bream a shot. I like to combine two types of fishing eg: barbel and artlure(bream) then the artlure keeps you busy while waiting for the barbel to bite. I'll bring some feed back after my next session on x-mas weekend. The bream I am usually catch is beween 10cm and 40 cm and usually blue and red breasted kurper.
J_Bay
I've found that small kurper, the ones you get on say warms and a float, I'm guessing about 10cm long have worked like champions. Nothing stops you going bigger though, I mean big cats will take a carp, I just found from experience that the smaller ones worked best.
