upgrade from penn 555
Noweeds
Nothing wrong with having another reel...there is no such thing as too many reels....horses for courses!!
ICTHYES
Hi rofflign
The bigest diff.i found between the penn and the torium is the retrieve.....it like walking the dog ....the restrieve is smooth and easy..,.what i havnt done and will be doing in next week is to fit a power handle and see what happens...
my 2cents
Polychaete
Does your wife agree with that statement?;)
[color=#006600]rofflign[/color] wrote:
thanx for all the feedback guys, I get about 100 - 115m with the 555 on my exage 1468 with 6oz sinker (no bait), the spool is set loose (ie you can just feel the play) and the brakes are disengaged. when  casting the rod loads nicely and I only brake the spool when the sinker drops. What I'm trying to find out is,will a tor30 or grandwave 30/50 make a difference all things being equal,if not I'll save the bucks and stick to the 555 as otherwise it is a good reel.
I think what you are describing is a pretty fair cast for the tackle though you don't say what line weight you re using.   A different reel may perhaps make a small difference but I don't think enough to warrant spending more money on it.
[color=#006600][u]dubzaddict[/u][/color] wrote:
Hi rofflign
my 2cents
Most of the new generation reels have a beautiful smooth retrieve if compared with older reels.   Some wear and tear in the gears of older reels is also a factor.   I don't' think that Penn 555 is a bad reel at all, certainly comparable with the Daiwa sl50sh or Shimano TLD star etc.
Noweeds
Just want to add one more thing......after fishing with my Toriums i could never go back to a 555, they are such a pleasure to fish with.
Not to confuse you any more. But all i was saying was if its purly distance that is your problem buying a new reel is maybe not the answer. However if you want a better all round reel for performance etc then get the torium!!
At the end of the day i suppose it comes down to finances!!
FStander
Well can I suggest something toally diffirent. What about the Daiwa Saltist (Expensive) or alternatively the Shimano Trinidad 20/30 - I have to admit that I LOVE my Trinidad and agree with some of the other guys here that the Daiwa's seems to give problems when exposed to saltwater. I too have the habit of dipping my reel in saltwater and offcourse when wading through the surf it gets a lot of seawater.
Again, consult an expert at a tackle shop for excellent advice.
regards
Frans
