I've recently opened a Triny to do a drag upgrade for a friend and was pretty disappointed at what I found inside, for what is Shimano's top end reel.
I can see why the drag is vrot only 3 washers, it has lots more bits and pieces then the Diawa's I'm more familiar with, and the side plate made from 2 pieces of pressed alloy, (looks like blik)
From what I've seen (from a distance)and schematic the Torium looks similar but many are in use and I've not heard any serious grumbles. I do read that the drags are also suspect.
Unless the faster retrieve is important to you, I would go for Torium, its a good reel and a bit cheaper.
As far as casting goes, I don't like any of these new reels because they leave no space for your thumb on the side of the spool.
