Trini 40
Moyeni
I only have Daiwa reels and a friend on mine wants to buy a Trini 40.
The problem he has is "how good is this reel for casting long distances (8/9oz)"?
He will be mainly using it for sliding baits.
To match this reel he has a Purglas 400/6.
Info would be great....!!!!
Abaddon
The reel takes a little acclimation but has a far gentler "Learning Curve" than its bigger sis the 50.. Your mate a capable caster?
If so, with a little practice, the Trini40 will become his new favorite reel! Tons of cranking power, super drag and a great line capacity to top off what, in my opinion, is THE BEST all round reel available..
That pairing is superb and well balanced! Should be casting a 9 ounce out of sight..
Perfect combo and will easily handle 10oz weights
My 400/6 has it's tip cut back a bit to give the same action as the 350/6 and it is perfectly balanced with a Trini 50 and 9 or 10oz
Trini 40 little better capacity than 30 but has bigger gear = cranking power, double dogs, larger anti reverse bearing, larger drag washer and casts as well as if not better than a 30 once you get the hang of it.
Can't go wrong
