I've been reading the forum for a while and got plenty of good tips from the numerous posts but now find myself with a problem I can't seem to find a solution too and wonder if there is any advice out there?
I've been using a Torium 30 to catch Bronzies with and the other day it started making a horrible noise. Opened it up to find the spindle shaft through the spool had snapped just above the bearing retainer pin on the right hand side of the reel. Namely where the pinion gear sits.
I have upgraded to crabontex washers and can only believe this is due to high drag forcing the shaft the pinion gear away from the main driving gear under high drags. Been fishing with 0.55 mainline with around ten kgs of drag.
It looks like I have to buy the whole new spool assembly, is this the case or is there a way of removing the spindle shaft and getting a new one?
Any advice would be much appreciated.
Thanks,
Alistair
Thanks,
Alistair
