Sounds like the pinion or the pin on the shaft that slots into the pinion or lastly the Yoke plate
Should it happen intermittently then it will be the plate or the pin on the cast control lever that activates the Yoke.
Either way it needs opening and a clean and lubrication and if required a part /parts to be replaced
