Torium 30 assembly advice
Benbreda
Can some one please help. I got some sand in my reel today. Decided to open it up so as to rinse out the sand. Decided to take the rightand cover of and now I am stuck. The shaft on which the star drag screws up and down has a small metal fiitting which fits into shaft against what seems to be a tensioning spring? Now that I have to screw the star drag back on it again the little protrusion stops it from screwing on completely and thus not leaving any space to put the handle back on. There are 3 washers with the smallest one closest to the star drag. I have tried with this washer on top of the little piece and underneath put no joy. How is it suppose to go together?  I have tried a forum search but have not been able to find some help.
Tks
Benbreda
I have found a tutorial on stripping and reassembling the torium 30 on the website bloodydecks.com (www.bdoutdoors.com) under the forum section. There is a small hole/channel running down into the shaft thru which one can insert a thin piece of steel to trap the click pin and spring in place until you have managed to screw the stardrag back on again. Very detailed instruction and photos to work from.
Sure I will be able to proceed with the reassembly now, I hope!
Mangi
Check under the FAQ section for reel maintenance and servicing. Trophy posted a brilliant tutorial on servicing a Torium 30. You can use a toothpick to hold the pin back while screwing on the star drag. Hope you come right.
Joker
What also helps is to put a small amount of grease on that small spring. Now insert the small clicker thingy and press it down as far as possible. Keep it down. Be careful not to let go. If it pops out, its a goner. Still pressing the little thingy down, insert a toothpick down the channel mentioned above and pin the thingy in place. Screw on the star over the small pin until you hear the clicking sound. Hope that helps.
Just make sure the toothpick stays in place and that small thingy does not pop out.
Psy
Benbreda wrote:
I have found a tutorial on stripping and reassembling the torium 30 on the website bloodydecks.com (http://www.bdoutdoors.com) under the forum section. There is a small hole/channel running down into the shaft thru which one can insert a thin piece of steel to trap the click pin and spring in place until you have managed to screw the stardrag back on again. Very detailed instruction and photos to work from.
Ben
Seems like you have sorted your issue out yourself? The 2 washers are also there to resolve the very issue.
Good luck.
Mango
Take that spring and put it behind the dog on the tor 30 then you have a torium that clicks. You wont be able to hear any click when turning the the star for the dragg stack does not affect the functioning off the reel in any form
