Hi All,
I use my Torium 20 with 0.4mm line and this weekend I casted the mother of all over winds, one of those that just jump out at you from nowhere, pity I din't have a camera, it would have won the photo comp. The snag is the line also went in between the frame and spool and wrapped itself around the ratchet mechanism about 700 times. *&^%$# it was a mess. Had to take off the left side plate on the rocks to get the line out. This is the type of thing that used to happen with the old jigmaster and they had an extra added that the rough spool edge cut the line off for you as well. Does anyone else with a Torium experience this using thinner lines? Perhaps my frame wasn't cast to the correct tolerances resulting in a wider gap between spool and frame?
Should I pursue this with Shimano, please advice. No Daiwa/Shimano comments welcome though. I also own Daiwa reels and they have their own little tricks they get up to.
Pylstert
Pylstert
