To rinse or not?
Titus
Hi
I have a Daiwa Crossfire-E 2500-3i reel with a Shimano Nexave rod.
When I purchased my reel the guy at Alcock’s Fishing tackle in PE said not rinse the reel after a fishing trip.
What do you guys think? Do I need to rinse it or not?
Titus
Shimaiwa
I personally rinse all my stuff, reels rods, with fresh water from a spray bottle after every outing as it gives me peace of mind that it will last longer. He probably meant don't rinse it under a strong jet of water which will push dirt further inside but unfortunately for you the quality of the crossfire is so bad the insides will rust quickly no matter how hard you try and I talk from experience. Your rod is good though
couta-koppie
 After a trip I tighten my drag all the way, then rinse the reel. This will keep the water off the drag washers and prevent it from becoming jerky. After rinsing I release the drag all the way so that it doesn't hold the memory and loose its drag capability.
Titus
Hi DD
Well I just started to do some dropshoting. Will get a better reel later when I'm bit more experienced and when the budget allows it so probably need to start saving.
My rod snaped on its first cast the other day. Luckily the guy at Alcocks replaced it for me. So far had no problems with it.
Titus
neilg
Hi Titus
hard to believe that the Alcocks will give you that advice. The only reason they could be saying it could be because people get water on the drag washers.
When fishing saltwater you need to clean your tackle after EVERY single trip, otherwise corrosion she will set in sooner rather than later.
I don't dip my reels, I take a damp cloth and wipe them clean, but it's important to do it properly.
I will speak to Chad about the not rinsing advice though.
